New Battery /Load Tester Has Arrived
Like Tree6Likes
  • 1 Post By bob2006
  • 1 Post By bob2006
  • 1 Post By rckstein
  • 1 Post By bob2006
  • 1 Post By bob2006
Old 19 Sep 2017, 03:04 pm
Default New Battery /Load Tester Has Arrived
My new Solar BA9 has arrived
While looking for a short, it was suggested that I test my battery.
The battery, starting system and alternator all passed as OK, with and without a load on them.
The BA9 also does a ripple test and that passed too.
So that leaves me with no idea, where in the heck, that parasitic power leak that is draining my battery is coming from.
The amps between the negative post and the negative wire are OK with and without fuses.
I have also cleaned the major ground point from the negative terminal to the body of the PT.
I am stumped.
Any suggestions on where I might look next would be most appreciated.
Thanks
NitroPT likes this.
Old 19 Sep 2017, 03:36 pm
_PTGT03's Avatar
Default Re: New Battery /Load Tester Has Arrived
make a new thread specific to your problem
Old 19 Sep 2017, 03:45 pm
What is your battery voltage with the engine running at 2000 rpm?
Old 19 Sep 2017, 10:20 pm
Lol
That's what I thought I was doing....
rob302 likes this.
Old 19 Sep 2017, 10:21 pm
I will have to check that and get back to you.
What should it be?
Old 19 Sep 2017, 11:04 pm
rckstein's Avatar
Do you have a copy of the Service Manual?
If not, I can PM you a link to download it from my Dropbox.
bob2006 likes this.
Old 20 Sep 2017, 12:46 am
I don't have a copy.
Please PM me.
Thanks for the offer.
rckstein likes this.
Old 20 Sep 2017, 12:53 am
_PTGT03's Avatar
Originally Posted by bob2006 View Post
Lol
when you make a thread topic title that's completely opposite to what you wanted help with, you only look like someone who can't even help them self.
Old 20 Sep 2017, 01:08 am
rckstein's Avatar
Please PM me.
PM sent with the links
bob2006 likes this.
Old 20 Sep 2017, 01:41 am
Downloaded
Thank you very much!
Reccomendations For A Battery Load Tester bob2006 General PT Cruiser Discussions 17 10 Sep 2017 10:07 pm
Turbo leak tester Pippov General Turbo Discussions 1 09 Apr 2016 07:47 am
Block Tester, blown head gasket lmarkie74 Tech & Performance Forum 8 15 Feb 2014 10:55 am
New Mod arrived! red06limited Exterior Accessories Forum 12 02 Jan 2012 12:05 pm
Stock Turbo, wideband, and leak tester Kawizx9r Classifieds: For Sale/Trade 1 13 Jun 2011 01:23 pm
