Windshield Washer Pump Location?
Like Tree11Likes
Old 21 Sep 2017, 07:23 am
SpaceMouse's Avatar
Default Windshield Washer Pump Location?
So the windshield washer pump in my '06 Touring Edition doesn't work, as in not even making a sound. Poked around under the hood and it didn't jump out and bite me in the butt, and not even a word about it in my cheesy Chilton "service" manual. Can someone point me in the right direction as far as finding the darn thing, and any tribal knowledge as far as not having to cough up $35,000 for an OEM replacement?
Thanks.
Old 21 Sep 2017, 07:30 am
Default Re: Windshield Washer Pump Location?
Maybe this will help...
https://www.moparpartsoverstock.com/...BoCY1YQAvD_BwE
windshield washer pump inop
washer does not work
SpaceMouse likes this.
Old 21 Sep 2017, 07:55 am
Handy_Cruiser's Avatar
Thanks.
It's inside the washer fluid tank beneath the plastic cowling in front of the windshield on the right side. You can see the washer fill cap sticking up there.
They rarely go bad. So if me, I'd use a multi-meter to check for current at the plug when the washer pump is supposed to be engaged. That way I'd know if it's really the washer pump, multi-function switch or something else.
If you find it is indeed the pump, consider a used one from a salvage car. You would just replace in the entire tank and all. To be exact, if you need one I have one I can send you if you pay shipping.
PS: Your 2006 PT likely has a cabin air filter assembly behind the washer tank. But it appears that the good folks at Chrysler didn't put any actual filter elements in them. While replacing the washing pump, it's a great time to add a cabin air filter element at the same time.
rckstein and SpaceMouse like this.
Old 21 Sep 2017, 07:58 am
SpaceMouse's Avatar
Thanks! Tried using the search tab and got 4,956 hits for water pump replacement threads.
Handy_Cruiser likes this.
Old 21 Sep 2017, 08:12 am
Ok good responses except the "rarely" going bad. We have replaced several Pt pumps mostly because people let the reservoir run dry which leads to a corrosion build up in the pump itself. The pumps are very cheap through all the internet sellers.
I WOULD NOT recommend a used on, its not worth it!
use this for your search to purchase one:
windshield washer pump pt cruiser
Old 21 Sep 2017, 09:38 am
They "rarely" go bad by themselves. Having owners do something that makes them go bad doesn't mean the pump isn't a lifelong part no matter how many have to be replaced.
Same goes for the fuel pump in the fuel tank. It's cooled and lubricated by the gas itself. When owners let the tank run dry or almost dry which burns out the pump doesn't make the pump bad.
Old 21 Sep 2017, 09:50 am
The failure of in tank pump assemblies varies depending on which state you live in. Unfortunately the different summer/winter blends offered in the gasoline available in states that are concerned with air quality can effect and shorten the life of those fuel pumps.
As for the wiper reservoir pumps failing in general well... I doubt that there is not one auto parts store anywhere that does not at least stock a universal replacement, and warehouse distributors I am pretty sure they are still on the at least the "B" if not "A" of stocked parts?
I personally would not call them a lifetime part?
Old 21 Sep 2017, 09:59 am
rob302's Avatar
I'd try fixing it first. I fixed my aunt's washer pump recently. Free to try
By fix I mean remove, clean, spin a few times by hand
Old 21 Sep 2017, 10:13 am
rckstein's Avatar
Thanks.
I sent you a PM with links to electronic copies of the Chrysler Service Manual, Parts Catalog and Owner's Manual, from my Dropbox, they may come in Handy
Old 21 Sep 2017, 11:14 am
767skyking's Avatar
Hmm... Nope. As Nitro stated, demographics plays a big part of longevity of a dc motor. Brushed electric motor and armature are highly susceptible to corrosion depending on area of location.
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
windshield washer pump inop 4SPEED General Turbo Discussions 11 09 Feb 2016 01:23 pm
Windshield washer adjustment? red98gt General PT Cruiser Discussions 6 02 Nov 2014 01:52 pm
windshield washer pump 4SPEED Tech & Performance Forum 3 12 Aug 2010 10:30 pm
windshield washer TOMisKING General PT Cruiser Discussions 1 29 Jul 2010 07:01 pm
relocate windshield washer rnbenoit Exterior Accessories Forum 6 03 Aug 2003 11:22 pm
