Thumping in front end
Old 24 Sep 2017, 07:25 am
RVC RVC is offline
Default Thumping in front end
This is picking up where Badglas' thread (Thumping in front end over bumps) left off.
I have a similar problem, although not quite. My right front end has a lot of thumping which varies with speed and with the position of the steering wheel. It is experienced in the steering wheel and can be felt in vibrations on the floor. It is also easy to hear. Yesterday, after I repaced the control arm (bad rear bushing), the thumping continued and did again just now although not so bad. It is worse when turning to the left, somewhat when going straight ahead and not so much when turning to the right. This is subject to change in intensity with no particular reason.
The sway bar bushings are in bad shape and can be heard going over bumps, but my problem noted above is much different.
I'm not sure where to look next. Could it be the tie rod ends? How about the right front wheel bearing? Thank you for whatever assistance may be forthcoming.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 24 Sep 2017, 08:03 am
Default Re: Thumping in front end
Maybe the strut mount bearing? IDK, just guessing.
Old 24 Sep 2017, 08:23 am
RVC RVC is offline
I feel kinda silly asking this, but... What is a strut mount bearing?
Old 24 Sep 2017, 08:43 am
Fk5 Fk5 is offline
Read that wrong. Strut mounts we all have.
I am starting to think that my problem is the intermediate shaft bearing, but...
the N/A cars don't have. The mount I am thinking of is on the intermediate shaft or a jackshaft or whatever you call it. The middle shaft added so that the left and right shafts are the same length. IIRC N/A cars do not have this "jackshaft" they just have unequal length shafts and I don't think those have those kind of bearings.
2003 GT 5 speed
162,000 miles
Old 24 Sep 2017, 01:18 pm
RVC RVC is offline
Never heard of a strut mount bearing. Looked it up and now I know. Thanks for the enlightenment but I'm pretty sure that's not the problem
Thumping in front end over bumps Badglas General PT Cruiser Discussions 23 09 Nov 2017 10:49 am
Help Front thumping noise 03GT100 Wheels, Tires, Suspension 6 18 Nov 2014 07:23 pm
Wheel well thumping... MadMax38 Wheels, Tires, Suspension 2 30 Jun 2013 03:15 pm
thumping sound pittguy Tech & Performance Forum 2 16 Dec 2010 09:47 pm
clutch thumping noise warpedhead General Turbo Discussions 2 23 Apr 2007 02:28 pm
