Help removing pins from SRS Plug
Old 25 Sep 2017, 09:50 am
Default Help removing pins from SRS Plug
Anyone know how to remove pins from the green SRS plug located under passenger seat? I found a crimped wire that might be causeing my SRS light to come on and would like to pull back this wire and re-pin. Unfortunately, after removing the white retainer, i still can't figure out how to remove the pin. The simple solution would be to just cut the wire and solder, but i'd like to keep it factory, as best as possible!
Old 25 Sep 2017, 10:05 am
Default Re: Help removing pins from SRS Plug
You are most likely gonna need depinning tool. A very thin flat needle that can disengage the tab that holds the metal sleeve inside the connector.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 30 Sep 2017, 04:46 pm
you need a set of the pin tools to do that without ruining the pins or connector,I bought mine around 15 yrs ago off the USA tool truck,snap on would be way too expensive
No grounds at OBD ii plug pins 4&5 betterred Tech & Performance Forum 5 27 May 2017 01:06 pm
New Door lock Pins WolfmanG Interior Accessories Forum 2 05 Jun 2011 08:17 pm
Lock Pins... ucantcme Interior Accessories Forum 5 01 Apr 2008 02:22 pm
hood pins MTL09 Exterior Accessories Forum 1 02 Oct 2004 05:23 am
