Timing belt replacement
Like Tree2Likes
  • 1 Post By ptcruisersteve
  • 1 Post By Moparman440
Old 26 Sep 2017, 04:43 pm
Default Timing belt replacement
I did a timing belt and water pump replacement on my 2001 PT Cruiser. I had a hard time getting all 4 timing marks lined up. The timing is off just a little but not much. The car is running good. No backfiring or spark knocking.
I would like to know:
1. would this cause any problems later?
2. Will I burn up my values or push rods?
again everything seems to be running good just don't want to cause any damage to anything
Old 26 Sep 2017, 04:55 pm
Default Re: Timing belt replacement
Wc
First you don't use the outer marks. What is your line up as you discribe it? So we can see what you have.
Old 26 Sep 2017, 05:19 pm
As Busted_PT posted you only want to look at the inner marks as show below.
Busted_PT likes this.
Old 26 Sep 2017, 06:26 pm
My current timing marks
https://pasteboard.co/GMdLk01i.jpg
https://pasteboard.co/GMdJZ3G.jpg
https://pasteboard.co/GMdKHJe.jpg
Old 26 Sep 2017, 06:33 pm
Ignore the green line. The inner red marks should line up with the center of both camshaft sprockets.
Old 26 Sep 2017, 06:55 pm
Here are my current marks. Are they on point if not will it cause any problems
Old 26 Sep 2017, 08:03 pm
Steve; I believe he is right. I've looked at all the pictures. And looks like on the top at least.
Old 01 Oct 2017, 08:27 am
Your upper marks look fine, but we can't see the lower one.
The thing to remember about the timing belt is that with the stock setup, you can only adjust it in one tooth increments. If you think it may not look textbook perfect, you can only move it by a whole tooth at a time. If a whole tooth in either direction makes it WAY off, then it was right the first time.
Did that make sense?
SpaceMouse likes this.
'05 GT Convertible Automatic (daughter's, she calls it "Matilda", I don't) and '05 Cool Vanilla Limited Turbo Lite "Vanilla Thrilla" (wish it was a stick shift)
Tags
timing, timing belt, timing teouble
Timing Belt Replacement.... PTMinotaur PT Cruiser Convertible Forum 9 10 Mar 2016 10:06 am
[Q] Timing belt replacement MadCobbler Tech & Performance Forum 6 02 Jul 2015 10:19 am
Timing belt replacement LRSRTGT General Turbo Discussions 2 06 Aug 2012 01:43 pm
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Timing Belt Replacement - What Next? johnjsa Tech & Performance Forum 5 22 Feb 2012 05:22 pm
