Same old stuck on defrost question
Like Tree2Likes
  • 1 Post By JoeX
  • 1 Post By Dewey068
Old 03 Oct 2017, 04:10 pm
Default Same old stuck on defrost question
I've got a basic 09. I pulled the center console out, un kinked the wire. Well, let's try something. I pulled the cable off of the direction selector and tried to move it through the tube myself. No luck. I'm guessing I'll have to take the dash out to fix it.
Any ideas? Thoughts? I do not want to take the dash out or pay some to do it.
Thanks.
Old 04 Oct 2017, 04:14 am
Default Re: Same old stuck on defrost question
I had the same problem in my 06 and my fix was to straighten the cable ant then I loosened the screw /bolt securing the other end of the cable to the AC housing. The cable moved much easier. If I remember correctly I was able to do this by opening the center cover like you did to straighten the cable and then through the glove box door.. or did I reach through the center cover..
Handy_Cruiser likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 04 Oct 2017, 07:03 am
I just fixed this on my 06. The cable had popped off the selector and the linkage had jumped timing on the blend door. I removed the glove box and went in that way. I removed the screw on the linkage cover, aligned the pin in the slot and popped in back in.
2006 Limited n/a RIP
Old 08 Oct 2017, 12:59 pm
Thanks. I'm going to try to our the glove box our later. Here goes nothing lol
Brake Question After Freeing Stuck Caliper chuzz General PT Cruiser Discussions 13 15 Aug 2016 05:56 pm
A/C does not come on in Blend/Defrost mode wingman55 General PT Cruiser Discussions 3 28 Aug 2015 11:05 am
2006 pt cruiser stuck on defrost Benjamin9669 General PT Cruiser Discussions 1 24 Jan 2014 05:31 pm
Heater/AC blows through defrost d2freak82 General PT Cruiser Discussions 3 01 Jan 2014 01:36 pm
Defrost selector flyinurse General PT Cruiser Discussions 1 11 Nov 2010 07:02 pm
