No spark
  • 1 Post By ptcruisersteve
Old 03 Oct 2017, 05:26 pm
Default No spark
Test the coil pack. Resistance from 1 to 4 and 2 to 3 is good. Tested plug from harness with a light tester. On center wire light bright and steady. On one outside wire no light at all and on the other dim and steady. This is with the coil pack unplugged. Not sure if cam or crank sensor. Any ideals, any help as where to go from here? Only code I am getting is a barometric out of range.
Old 03 Oct 2017, 05:28 pm
Default Re: No spark
If no spark related engine trouble codes I would suggest taking the camshaft sensor off, crank the engine and see if the camshaft is turning.
ptprice likes this.
Old 03 Oct 2017, 06:01 pm
Could it be the pcm
Old 03 Oct 2017, 06:21 pm
Also according to scanner timing is +9
Old 09 Oct 2017, 06:59 pm
check to see if you have injector pulse, if it don't,then it should be a defective crank sensor, if you buy one, buy a OEM, the aftermarkets don't work on the Chrysler products too well
No spark 1&4... abusby Tech & Performance Forum 9 15 Aug 2013 12:51 am
'07 PT no spark thunderfoot Tech & Performance Forum 7 08 Dec 2012 05:56 pm
No spark, turns over but no spark? magic1021 Tech & Performance Forum 26 15 Sep 2009 07:50 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
Spark Gap kennybopaloo General Turbo Discussions 13 31 Mar 2006 05:09 pm
