Squeal or whistle after revving possible vacuum leak or power steering pump
Like Tree4Likes
Old 10 Oct 2017, 06:36 pm
Default Squeal or whistle after revving possible vacuum leak or power steering pump
https://youtu.be/R0FedtOs5oY <<< so this just started today. Click the link to watch the video I took of the issue.
Can anyone help me diagnose this annoying noise? I first thought it could be a vacuum leak but it's hard to tell where it's coming from I don't have a stethoscope. I am getting the impression it could be from the power steering pump. Serpentine Belts and tensioner are all new. Not the timing belt components though. Which I have an appointment for a timing belt job this week and it's going to cost over $1600 but this noise just started and I'm not so sure anymore that I want to sink more money I don't have into it. What do?
Old 10 Oct 2017, 11:09 pm
_PTGT03's Avatar
Default Re: Squeal or whistle after revving possible vacuum leak or power steering pump
the cost of that timing belt job just totalled your vehicle. where are you getting it serviced ? i wouldn't pay that cost, it seems unreasonable.
check out https://repairpal.com
with the money you saved, ask for a turbocharger boost pressure testing kit be applied. most likely there is a fault in that system. sounds like an air leak somewhere.
Old 10 Oct 2017, 11:17 pm
Yea I know, this shop is willing to work with me too since I only have $1000 and not the whole $1633 that is needed to replace the timing belt, water pump, idler and tensioner, also cam seals. Your link also brings me to around the same price. Everywhere I looked I get those quotes, it sucks. The shop will let me make the rest in payments, should I do it or cancel? Anyways, the noise I determined is the power steering pump. I added some atf4 and it went away. I plan to suck up the fluid and replace it with fresh fluid ASAP. I bet replacing the power steering pump is a PITA as well huh. I bet I could do that job though.
Old 11 Oct 2017, 01:07 am
Prices are going up, I called three dealerships near me for the 102,000 mile service, which is the timing belt, flush, etc. and the prices, less the oil change, were $1600, $1500 and $1200!
Old 11 Oct 2017, 11:30 am
ptprice's Avatar
Timing belt replacement should be in the range of $700 to $1000. This'd be at a reputable shop though, not a dealership.
Instead of a stethoscope you can press a long screwdriver to areas of your engine to determine source or location of the sound. Put your ear at the end of the handle. Yup, it's make shift, but works like stethoscope. Soap and water might spot a vacuum leak.
Happy PTin', ptprice
cloudhidd3n and Sinbad like this.
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Old 11 Oct 2017, 01:21 pm
A piece of 1/2" heater hose with a funnel stuck in one end works pretty well for finding noises like that too. And you're right, on the turbo, it's a pain to replace the power steering pump.
cloudhidd3n likes this.
Old 11 Oct 2017, 03:43 pm
So it's a vacuum leak i'm 99.9% sure. I'm smoking it out with a cigar to find the exact location, stay tuned I'll post back with result on where it's located. If I don't fix it my mechanic will when I drop her off tomorrow for the timing belt job. It's coming from the front around the intake manifold so it's either a gasket or inter cooler piping.
Old 13 Oct 2017, 05:15 pm
What do the lower and upper intake manifold gaskets look like are they two big gaskets or are they 8 individual o-ring gaskets for the turbo motor
Old 16 Oct 2017, 08:45 pm
$1700 later and timing belt, both cam seals, water pump ands lower motor mount replaced. Later that day after getting my car out of the shop I changed the intake manifold gaskets the noise is gone and engine runs great and holds boost.
Old 16 Oct 2017, 10:05 pm
_PTGT03's Avatar
good for you.
but really $2000 on a lower miles, better taken care of car and condition could have been a choice .
turbo power steering pump leak 2_cruisers Tech & Performance Forum 1 12 Feb 2017 08:15 pm
2.0l Touring Edition - whistle with revs; vacuum leak? Prostheta Tech & Performance Forum 8 29 Oct 2016 07:21 am
Power Steering pump codesguy General Turbo Discussions 0 23 Aug 2016 05:21 pm
01 Power Steering Pump hoje00 General PT Cruiser Discussions 1 15 Apr 2010 06:41 pm
power steering whistle ptTurbo528 Tech & Performance Forum 5 25 May 2006 05:33 pm
