2007 base pt rear turn signal issue
Old 20 Oct 2017, 01:46 pm
Default 2007 base pt rear turn signal issue
Hi! The left rear turn signal acts like the bulb is bad. It's good.
Has new bulb socket. Reads 11.??? Voltage at socket. Seems not enough amperage to light the bulb. ??
Old 20 Oct 2017, 04:10 pm
Default Re: 2007 base pt rear turn signal issue
hold a jumper lead to the socket and to the body, with the turn signal
on .. did it act normal??
Old 20 Oct 2017, 07:05 pm
How much voltage do you get when you turn the hazard lights on? Also with the brake light on?
Old 21 Oct 2017, 08:06 am
Check the contact points in the socket and on the bulb. Sometimes they need a little scuffing to make a solid connection.
Old 21 Oct 2017, 09:50 am
contacts are good n clean, haven't checked voltage with hazards or run a jumper from socket to fender yet. This car have canbus system? Is there a module that operates the rear lights? If there is, what's it called and where's it at?
Old 21 Oct 2017, 10:42 am
[/QUOTE]
New multi-function swt. & no lft rear turn signal. Michaeld55 General PT Cruiser Discussions 4 08 Apr 2017 02:49 pm
WTB: Rear Turn Signal Socket sifu_scott Classifieds: For Sale/Trade 1 30 Dec 2013 02:42 pm
Turn Signal Problem 2007 Pt Twinb2 General PT Cruiser Discussions 4 26 Sep 2012 02:46 pm
Turn Signal Issue-Please HELP!!! 2002ptcruiserwoody723 Exterior Accessories Forum 1 28 Oct 2009 12:27 pm
Rear turn signal problem leroy420 General PT Cruiser Discussions 5 18 Feb 2009 09:43 pm
