Rear running lights and break lights out
Like Tree2Likes
  • 1 Post By ptcruisersteve
Old 20 Oct 2017, 08:37 pm
Bigsid2007pt's Avatar
Default Rear running lights and break lights out
Hey guys
I have a issue my red running lights are out and so are my break lights. All three are out I checked the bulbs and the fuses and replaced the break switch still nothing. I do not have the money to pay a shop $80.00 a hour to figure out what is wrong with the car I am ready to shot myself or the damn car. HELP.
Old 20 Oct 2017, 08:56 pm
Default Re: Rear running lights and break lights out
Does the hazard lights work?
LionPT likes this.
Old 21 Oct 2017, 07:07 am
LionPT's Avatar
Check your fuses under the hood, I forget which 2 to check...I think it's in the teen or twentys....sorry. It is not marked as brake, I have it posted on site somewhere...
Old 21 Oct 2017, 10:20 am
Have you checked fuse #3 under the hood. The main brake lamps have no fuses and are controlled by the TIPM. If the third brake lamp is also out check fuse #3 as that fuse feeds the brake switch
Old 21 Oct 2017, 11:14 pm
Yeah I checked all the fuses #14 was bad but I changed it and that did not work. I had my AC serviced 4 months ago and three days ago when the lights went out I opened the goodness and found a wrench that is not mine could it have shorted something out?
Old 21 Oct 2017, 11:43 pm
Old 22 Oct 2017, 09:26 am
I have to check again the blinkers work and the white back up lights work just no red lighted both on the fenders and the window. I will check the hazards this morning. Just woke up.
Old 22 Oct 2017, 10:05 am
LionPT's Avatar
Check Fuses 8 & 13 Also check Grounds 302 & 303
Click For Full Size
Old 22 Oct 2017, 11:36 am
Click For Full Size
+1
If you have a voltmeter check the voltage on both sides of fuses 3, 8, & 13. The fuses might be good but you might not be getting voltage to those fuses.
Is there anything else not working besides the running lights, brake lights, and windows?
Old 22 Oct 2017, 06:37 pm
Yes the hazard lights are working. Trying to remember where my meter is to check the voltage and ground. But is there any way a wrench left under hood could of hit something that shorted something out. As I said I got the AC serviced 4 months ago. When all three red lights went out I popped the hood and this #11 snapon wrench fell on the ground
Gauge cluster lights, shifter lights, and rear running lights out Jspata Tech & Performance Forum 3 18 Oct 2016 04:33 am
ABS, traction lights, parking break lights ON and Cruiser control doesn't work Fab Feedback and Support 0 08 Jun 2015 08:28 pm
2001 no dash lights no rear running lights beley83 Tech & Performance Forum 6 01 Apr 2015 08:37 pm
Rear Break lights out (already replaced brake light switch replacement) Got337 General PT Cruiser Discussions 7 11 Mar 2015 08:36 am
Running lights/break lights leigh General PT Cruiser Discussions 2 25 Apr 2013 09:21 pm
