Gear shifter has been tight when changing positions and is now broken car won't start
Like Tree3Likes
  • 1 Post By LionPT
  • 2 Post By RickinPA
Old 22 Oct 2017, 03:43 pm
Cool Gear shifter has been tight when changing positions and is now broken car won't start
Hi! Obviously I'm a newbie! My 2008 PT won't start and I have a feeling it's not serious but I'm a woman and don't want to be hit on the head! Plus, even worse, the car now will not start and I need my SNEAKERS! Over the last couple of days, I've noticed that my gear shifter in my automatic PT has been getting very tight when switching from park to all other gears and vice Vera's back into park. This morning I went out to the car and it wouldn't start at all. (Battery is 4 mos. old and electrical system is fine). I then tried the gear shifter as I remember having a problem with a Jeep I had back in the 90's that I'd sometimes have to rock it and it would start. Much to my surprise, the shifter very very easily went from park to D2 and back! Does anyone know what this could be and how in depth of a project is it? If it's easy enough, I might just try my hand at it myself unless you feel otherwise. Just really needs my sneaks back( Thanks in advance, Dee
Old 22 Oct 2017, 03:49 pm
LionPT's Avatar
Default Re: Gear shifter has been tight when changing positions and is now broken car won't s
Sounds like the shift cable was binding, but now is broken.
There are a couple of users on site that have replaced thiers..and a few YouTube videos.
wingman55 likes this.
Old 22 Oct 2017, 07:09 pm
wingman55's Avatar
I had a Dodge Caravan that did the same thing... Had to replace the shift cable. Turns it had been installed wrong and was binding.
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
2004 Limited Edition Platinum Series, Graphite Metallic, Standard Turbo, automatic, RBQ radio with Sirius Radio & 6 CD changer, VentShades, chrome exhaust tip, door spears, grille inserts, door lock pulls, bright pedals and steering wheel spokes. Red spoiler from a donor PT. Known as: "The RATMOBILE" I bought it Apr 28th, 2016 with 62,400 miles on it.
Old 22 Oct 2017, 07:25 pm
VsandFords's Avatar
Welcome to the forum from Texas. Hate to hear about the problem with your Cruiser and your sneaks! If it is the cable and you have some skills, you can do this.
Where are you located, someone may know of some good reputable help close to you if needed.
Old 22 Oct 2017, 07:39 pm
RickinPA's Avatar
Just to add to what the other's said:
Automatic transmissions have a "neutral safety switch", which in your case is a "neutral safety switch / range sensor", located inside the transmission. This switch makes sure the transmission is in either Park or Neutral before it allows the starter to start the engine. If the cable broke, the transmission may not be in Park, and that could be why it will not start.
Also, I would recommend making sure the parking brake is firmly set, as the transmission may not be in Park.
myckee and SpaceMouse like this.
Tags
gear shift problems
2001 PT Cruiser Limited Edition shifter really tight Bandit2014 Tech & Performance Forum 8 21 Mar 2015 05:18 pm
timing belt gear broken??? mdskinner731 Tech & Performance Forum 5 31 Dec 2011 04:01 pm
Gear Shifter ucantcme Interior Accessories Forum 12 05 Apr 2008 08:43 am
Gear Shifter cruisergeo Interior Accessories Forum 8 07 Jan 2004 03:11 pm
my new gear shifter cmypt Interior Accessories Forum 1 14 Jan 2003 01:31 pm
