Post purchase inspection questions 2006
Like Tree2Likes
  • 2 Post By ajhockey3
Old 25 Oct 2017, 09:31 pm
ajhockey3's Avatar
Default Post purchase inspection questions 2006
Just purchased this car, I did a good amount of pre purchase inspection but not as much as I probably should when looking at fine details have some questions.
The rear passenger power windows motor is slow and makes a sound like it's going to die any second. Is it an easy fix or a hard Process? I have removed the door panels on other cars but not on a cruiser and I have never replaced a power window motor.
Is the interior light, the one in the middle, have a switch somewhere? It doesn't turn on when keys in the ignition or when the doors are open. I checked the fuse looks fine haven't replaced the bulb. Also there appears to be a small light beside the outlet in the trunk, and that one doesn't turn on too. Are they wired in series and ones dead? Is there a switch I haven't found? Are both bulbs just dead?
Is it common for the trunk release to be finiky? Sometimes it opens no problem multiple times in a row, sometimes it won't budge at all, usually clicking unlock on the key a few times and trying again will release the trunk.
Is the latch mechanism dying or is it just how it tends to be?
Thanks guys, sorry if these questions seem dumb, new or owner, kind of grew up around GM vehicles
Old 25 Oct 2017, 11:50 pm
rckstein's Avatar
Default Re: Post purchase inspection questions 2006
Welcome to the forum
All of the interior lights should be on at the same time when you open the doors or turn the switch on the light stalk on the left hand side of the steering wheel. You may just have a couple of burned out bulbs.
Are you talking about when you reach under the rear handle to press the touch-pad switch for the rear hatch? If so, then the touch-pad switch may be going out. You can check this forum for how to add a replacement switch rather than replacing the entire rear emblem to fix that issue.
Old 26 Oct 2017, 06:38 am
LionPT's Avatar
Depending on how your remote is setup...1 click will open drivers door & 2 fast clicks will unlock the others..including the hatch. If the drivers door is already unlocked, you still need to do 2 clicks.
You can also program the remote to unlock all doors on 1st click if you want.
Old 26 Oct 2017, 07:30 am
Welcome to the forum. Good luck with your PT.
Old 26 Oct 2017, 02:29 pm
ajhockey3's Avatar
Well I wished I would have checked this thread before I left this morning, Just bought two new bulbs this morning popped one in the car before figuring out the lights on the stalk. The previous light worked, but it was fairly old looking, So I'm not upset about spending $6.5 at Canadian Tire for a 2 pack
rckstein and Carnut like this.
Battery Then Check Engine Light Comes On After TX Auto Inspection (2006 PT Cruiser) EuroCultAV Tech & Performance Forum 10 19 Nov 2017 05:53 pm
I have several questions in deciding to purchase a GT Convertible. PLEASE HELP! Tobywong PT Cruiser Convertible Forum 8 02 Jun 2010 12:24 pm
fell in love with PT (have questions before purchase) LawChick General PT Cruiser Discussions 18 27 Jul 2009 10:59 pm
