no start under 50 f.
  • 1 Post By chuzz
Old 26 Oct 2017, 11:09 am
Default no start under 50 f.
howdy,our 02 pt cruiser, 2.4. has had this problem for aslong as i can remeber, its not that cold in missouri at the moment but when it drops bout 50 or below the car has trouble starting, sometimes we are lucky and it starts on a crank, otherwise after 2-3 times trying to start we dont even hear starter kick over at that point. and will require a jump. last jan. no matter whats fixed or not starts bout now and gets worse til bout early spring. i will be replacing battery wires thisweekend (cleaning up 7 years of maintenance neglect) among random things everyso often, just replaces spark plugs and wires, (they burn out bout every 6 months.) the cpu was replaces when they first bought to to previous owner crushing with after market parts. if any answer or any options to try would be awesome. thank yall for your time.
Old 26 Oct 2017, 11:15 am
Fk5 Fk5 is offline
Default Re: no start under 50 f.
If it starts with a jump that sounds electrical. Clean and check all the connections and have the battery load tested. You shouldn't really have to throw parts at it, just test it when it is acting up and see where you are losing voltage or whatever. I forget the terminology, and have to double check every time I pull the multimeter out.
FWIW, I had a similar problem on my 'cuda when I was a kid. Would not start cold, but once started would run all day. Jumping it or changing batteries would not help. Spent a winter pushing it back and forth across the street for alternate side. Turned out there was a pinhole in the fuel line. Not sure why it only acted up in cold weather, but when I fixed that up (okay I just hacked out the damaged section and replaced it with rubber line and a filter) it has been fine ever since.
2003 GT 5 speed
162,000 miles
Old 26 Oct 2017, 01:18 pm
ty, the other day when i replaced the plugs and wires i cleaned of connections at the battery. the battery is only a year old and was replaced when these problems got worse last winter. no effect. the uused car place they bought it from had a system that would shutdown the car with lack of payment and had to have a xode to get it working. a shop took the device out bout a year ago. bit was thinking perhaps the messed with the electrical when installing the equipment. there a few loose wires with dead ends. morrow iam going to check the wires to and from and check the relay box and connections. ty for your time and imput.
Old 26 Oct 2017, 01:34 pm
I am suggesting you might have an electrical or wiring problem.
I would suggest checking the wiring for the camshaft and crankshaft sensors. Sometimes when someone starts working on a PT Cruiser they will pull on the wire harness and break a clip underneath the engine holding it in place. The wire harness falls down and starts rubbing on the half shaft. Go underneath the
PT Cruiser and see if the harness wires are shorting to ground rubbing on the half shaft or the frame. This is a common problem for the 2001 & 2002 PT Cruisers.
Old 26 Oct 2017, 03:58 pm
oldthom's Avatar
Just to throw a fly in the ointment here. When you turn the key on the injectors will double click to get some fuel to the cylinders. Assuming that is happening, the IAC should open up for a start. Is it cold enough to cause a dirty IAC to be sticking? At least it would not hurt to clean up the IAC. With that you MUST disconnect the battery long enough to let it forget the no start condition. And clean that throttle body while you are at it....Just another idea, don't beat me up to much...
2004 LE "Dolly" 61K miles
Old 27 Oct 2017, 07:16 am
Ehhh, have you checked the ground connections on the drivers side fender? You'll need to remove the air box to get to them. This has been known to be a trouble spot for the PT's, too.
oldthom likes this.
Tags
battery., cold, not starting
Stalled while driving, key to start, no click or start farmerhope Tech & Performance Forum 30 08 Feb 2016 03:44 pm
Will not start Eculv Tech & Performance Forum 3 09 Nov 2013 06:04 am
help my pt won't start reignama Tech & Performance Forum 2 02 Jan 2013 02:54 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
What a way to start the day!! Knotsobright1 General PT Cruiser Discussions 7 06 Oct 2009 12:00 am
