No Interior Lights
  • 1 Post By sanatanadharma
Old 28 Oct 2017, 11:26 am
Default No Interior Lights
I have no interior lights,,,,2002 PT Limited,,,no lights on dome or map lights,,fuses for interior and and overhead console good,,,,im stumped,,any help much appreciated
Old 28 Oct 2017, 11:31 am
Default Re: No Interior Lights
Maybe something as simple as the dimmer wheel?
n/m You would still have map lights.
2016 Kia Soul Plus Black
Old 28 Oct 2017, 12:05 pm
Did you check both under the hood and in the dash fuses?
Old 28 Oct 2017, 01:08 pm
cannot find fuse under hood that would control interior lighting ???
Old 28 Oct 2017, 01:41 pm
Have you checked fuse 10, 13, & 14 in the fuse block?
Old 28 Oct 2017, 02:29 pm
Do you have lighted vanity mirrors in the visors? Are they working?
If not, check fuse #18 (20 amp) in the under-hood PDC (power distribution center)
If it is bad, you lose all of the functions of which you speak
It protects the dash fuse circuit #13
Old 28 Oct 2017, 04:53 pm
I seem to have power at the dome and overhead but no ground,,,when i pulled the dome the underside of the headliner is soaked,so i obviously have blocked drain tubes and probably,corrosion at the grounds,i'm guessing
Old 28 Oct 2017, 05:44 pm
The lighting system for the courtesy lamps (come on with door opening) and the system for the adjustable illumination (via the rheostat control on the lighting stalk of the MFS), are both grounded through the switch and the instrument panel
Your observation of wetness suggests grounds are indeed the likely problem
Interior lights Dream1 Tech & Performance Forum 2 30 Aug 2017 05:04 pm
Interior Lights GrapeApe Interior Accessories Forum 19 30 Nov 2016 07:18 am
Fog Lights and interior lights stay on kevinmellett General PT Cruiser Discussions 10 24 Nov 2014 10:54 am
LED Interior Lights!! skylinekin Interior Accessories Forum 25 19 Jul 2009 10:45 pm
Interior lights? calicruiser Interior Accessories Forum 4 22 Jun 2009 02:54 am
