PT Cruiser Timing Belt - First engine mount
Like Tree7Likes
  • 1 Post By ajhockey3
  • 1 Post By Handy_Cruiser
  • 4 Post By ajhockey3
  • 1 Post By Silver_Sleeper
Old 30 Oct 2017, 12:41 pm
ajhockey3's Avatar
Default PT Cruiser Timing Belt - First engine mount
My goal was to get the belt OFF tonight, But doesn't look like its going to happen
I cannot remove the bigger 18MM bolt, When I wrench it out, it goes 3-4 rotations of the bolt going out, Than the bolt underneath spins with it so it goes nowhere. I can't fit plyers down there,
A wrench doesn't hold onto it not enough of the bolt sticks out
socket won't grip it, only a few MM of the bolt sticks out and the surrounding metal isnt flush so It won't grip onto it properly
I can not get this bolt out, I spent 2 hours trying everything I could.
Please help before I scap this thing, very annoyed and frusterated
Handy_Cruiser likes this.
Old 30 Oct 2017, 12:50 pm
Handy_Cruiser's Avatar
Default Re: PT Cruiser Timing Belt - First engine mount
Here's what's happened.
There's a nut on the bottom of that bracket that the big bolts screws into. This nut slides in a "track" so you can adjust the top strut. What's happened on your PT is that the nut is spinning in the track. This happens pretty often.
The solution is to get an end-wrench on that nut. With the right wrench, there should be enough of the nut sticking out from the track that an end-wrench will fit on it. I've done this myself on two of my PT's. To make enough room to do this, go ahead and take the strut loose on the front side and then push it toward the right fender. This will make room to get your hand below the bracket where you can get a wrench on this nut.
You will likely never see the nut. So this is going to be done by feel alone. I believe the nut is an 18mm. But I am not sure I remember. So be prepared to try several sizes.
oldthom likes this.
Old 30 Oct 2017, 02:04 pm
ajhockey3's Avatar
Finally got it off, It is an 18mm, I couldn't fit the whole wrench so I had to genuinly cut it in half. But son of a bitch is off now
Old 01 Nov 2017, 09:20 am
You could have also unbolted the mounting bracket from the strut tower. If I remember correctly, it has only 2 bolts (15 mm?) One facing the front and the other faces the driver's side. You would also have to remove the bracket for the cruise control actuator/diaphragm - vacuum actuators, but you got it off.
BTarb24 likes this.
03 gt 5 speed Stage 1
Whoever says "There's no replacement for displacement " obviously underestimates RPM
Does 2006 PT Cruiser have non-interference engine? (Timing Belt Broke) HobbyJim2010 Northeast PT Forum 2 11 Aug 2017 09:22 am
PT Cruiser Timing Belt,motor mount etc. trigto Tech & Performance Forum 2 20 Jul 2015 06:07 am
[HELP] In need 2001 PT Cruiser 2.0 Engine power steering timing belt sabun General PT Cruiser Discussions 10 16 Jun 2014 03:52 am
Please Help!! Timing belt replaced and having engine problems tylines69 Tech & Performance Forum 9 20 Aug 2013 10:05 pm
timing belt, how long will it last on 2.4 engine BrianW Tech & Performance Forum 27 15 Mar 2011 10:40 pm
