05 PTGT A/C 10a fuse blowing, bad high pressure switch or ??
Old 03 Nov 2017, 06:16 pm
Default 05 PTGT A/C 10a fuse blowing, bad high pressure switch or ??
Checked for grounding in both switch connections, both good.
Relay is good.
LP switch is good.
Fan does kit on when AC is switched on, but that blows the fuse.
The pump itself doesn't physically sound very good. Pretty sure the bearings are giving up.
So, can the bearings for the pulley be replaced without replacing the whole pump.
AND, am i correct on assuming the HP switch in the pump is bad and grounding out when switched on??
Want to be sure before dishing out the $$$
Old 03 Nov 2017, 07:24 pm
Default Re: 05 PTGT A/C 10a fuse blowing, bad high pressure switch or ??
What is the number of the fuse that is blown. There is more than one fuse connected to the A/C system.
Old 03 Nov 2017, 08:05 pm
It's the small 10 amp fuse under the hood near the relays, don't know what number it is. Didn't see any other fuses anywhere else. I checked the box near the steering wheel. Didn't see any for ac there
Old 03 Nov 2017, 08:27 pm
Old 03 Nov 2017, 11:10 pm
Likely fuse #11 (10 amp) which protects the A/C compressor clutch (through a relay in the under-hood PDC)
2002 pt cruiser blowing asd fuse at high rpm gordon2418 Tech & Performance Forum 30 12 Oct 2016 09:31 am
HELP! Replaced MF switch and now hazard fuse keeps blowing... PTchick03 Tech & Performance Forum 2 05 Oct 2013 05:39 pm
A/C High Pressure cut-out Switch myanez Tech & Performance Forum 2 03 Oct 2011 09:59 pm
High beam fuse keeps blowing 92awd4g63 General PT Cruiser Discussions 5 23 Nov 2010 03:18 pm
Blowing Multifunction Switch Fuse (Non-Fog Lamp car) Rybo Flavin General PT Cruiser Discussions 2 12 Jul 2010 08:59 am
