OEM CD/Radio to Ignition Switch problem
  • 1 Post By sanatanadharma
Old 05 Nov 2017, 04:28 pm
Default OEM CD/Radio to Ignition Switch problem
Gremlins on my 2004 GT High Output Turbo with stock radio/6 cd player. Infrequently the radio will not turn on or if on, no display. Jiggle the ignition key and it will come on and the display will light up.
Assume it is a loose wire at the ignition switch. Any advice on how to correct this??
How hard is it to work on the switch and what wire and markings will it be. I have no wiring diagrams.
Many thanks
Harry
2004 GT HO Turbo, 5 speed, one owner, 83K miles
Old 05 Nov 2017, 05:25 pm
Default Re: OEM CD/Radio to Ignition Switch problem
Here is the wiring information for the ignition-switched circuit to the radio
Ignition switch connector pin #2, black/white wire to dash fuse block
Yellow/red wire from fuse Fuse #14 (20 amp) to radio (their is a splice)
At the radio connector pin #2, the wire color is red/white (changed at splice)
If the ignition switch is the problem, your front and rear wipers should also not work when the radio doesn't; the black/white wire to dash fuse block feeds both fuse #14 and fuse #15(wipers)
The ignition switch can be removed and disassembled and cleaned up
I had a tutorial on the forum until the vandals sacked the system and my library was lost
harry likes this.
Old 07 Nov 2017, 06:40 pm
push key in and see if problem goes away,works on mine
Old 04 Feb 2018, 05:36 pm
Yep, same thing with me.
Looking for a permanent fix.
Anyone have any ideas before I install my new Crutchfield Pioneer harness?
Gotta be a problem/connection at the switch.
Thanks
Harry
Old 05 Feb 2018, 09:14 am
On my 03 GT, I could get mine to function correctly by jiggling the tilt mechanism on the steering wheel. I put a zip tie around the connector that runs from the wheel to the radio and that fixed mine. I THINK it was the top one on the left, but not 100% sure. You'll need a schematic to look at to make sure you get the right one. I no longer have the GT to go look at.
Tags
ignition wires, radio problems
Replaced ignition actuator switch, now radio display doesn't work Caelestis General PT Cruiser Discussions 11 19 Jun 2016 08:54 pm
Ignition Switch / Random Stall / Loss of Radio - HELP DagnyT Tech & Performance Forum 11 31 May 2014 12:03 pm
new ignition switch problem PLUTOisAplanet Tech & Performance Forum 3 03 Jul 2013 05:20 am
Ignition Switch Problem? jjensen101 General PT Cruiser Discussions 8 11 Apr 2013 07:15 pm
possible ignition switch problem skisbabe Tech & Performance Forum 3 02 Oct 2012 01:41 pm
