What are these for?
Like Tree8Likes
Old 09 Nov 2017, 05:01 am
Default What are these for?
Wondering what the function of these is?
Pic 6721 is located in the rear on the passenger side (fuelpump??).
Pic 6754 is under the drivers side fender hanging loose and considering the oxide on the contact it's never been connected to anything.
Pic 6762 is some vacuum thing below the passenger side headlight
Old 09 Nov 2017, 06:33 am
LionPT's Avatar
Default Re: What are these for?
That is the vacuum container for the Cruise Control.
Old 09 Nov 2017, 02:43 pm
rcktpwrd's Avatar
#6721 is part of the vapor recovery system for emissions control.
#6754 could be for the fog light wiring harness if your can does not have them.
Joel
www.rcktpwrd.com
Old 13 Nov 2017, 04:14 am
6754 i don't think it's for the fog lights as they are wired on my car, any other ideas?
Old 13 Nov 2017, 09:44 am
rcktpwrd's Avatar
Sorry, I have no other idea then...
Joel
www.rcktpwrd.com
Old 13 Nov 2017, 07:05 pm
Connector (C107 0r C108) for the side repeater lamps found on the fenders (rear of front wheels) on some European vehicles
I expect you will find one on the other side as well
rockandroller likes this.
Old 13 Nov 2017, 07:20 pm
rckstein's Avatar
Martin has an export PT, I have pulled his Build Sheet and his PT does have the Side Repeater Lens, so if that's what that connector is for, it should be plugged in.
Martin, are your side repeater lights working?
Handy_Cruiser likes this.
Old 14 Nov 2017, 04:53 am
If the side repeaters are the ones that i marked on the picture, then they are working fine without this cable connected, also this cable does not exist on the passenger side.
Old 14 Nov 2017, 03:35 pm
New answer
I now suspect that the connector is for the siren used in some European vehicles equipped with the premium vehicle theft security system (VTSS)
It is also a black four-pin connector, located on the left side
rckstein likes this.
Old 14 Nov 2017, 05:14 pm
Man, if everything is working as it should, I'd put some electrical tape over it and forget about it. It doesn't matter if everything else works the way it's supposed to.
the3dgm likes this.
