Newbie with hi beam issue - '05 PT w/o fog lamps
Like Tree4Likes
Old 13 Nov 2017, 01:59 pm
Default Newbie with hi beam issue - '05 PT w/o fog lamps
Hello everyone, newbie checking in - own a '05 PT Cruiser (base model w/o fog lamps). Very glad to have found this forum.
My question is this...anyone here have an issue with the hi beams not coming on? The indicator light on the dash comes on but the hi beams do not. I've replaced the bulbs, the multi-function switch, and the relay but still no luck. If it's a ground wire issue, where are they located?
Old 13 Nov 2017, 03:08 pm
Default Re: Newbie with hi beam issue - '05 PT w/o fog lamps
I would suggest checking fuse #16 under the hood PDC.
oldthom likes this.
Old 13 Nov 2017, 03:58 pm
1st check the fuse. If the fuse is good, you can check for ground issues with a multimeter or a test light. Turn the high beams on and pull the bulb. Put the leads of the meter or light across the plug. If you get don't get voltage or the test light to go on, try moving the ground lead to a clean metal point on the car. If you get voltage or the test light goes on, you have a ground issue. I had a bad ground on the right side and just ran a new ground to a bolt on the frame.
2006 Limited n/a RIP
Old 13 Nov 2017, 05:04 pm
Fuse is good. Where exactly are the grounds that pertain to the high beams?
Old 13 Nov 2017, 06:52 pm
Do you have voltage going to fuse #16? If not check C105 connector.
There are separate grounds for the left and right high beam.
Old 14 Nov 2017, 11:06 am
Ok, suspect this is what's going on. Tested voltage at the left (driver's side) connector, got 12v but if I plug the bulb in, it doesn't come on. Cleaned up the connectors on the left side, no change. Where exactly is the ground on the right (passenger) side? Do you have to remove the plastic wheel well covers to access it?
Old 14 Nov 2017, 11:20 am
Have you considered that the power feed is weak and any load on it brings the voltage down? How is the separate ground connections applying to both high beams not working?
There has been threads on the wiring behind the fuse box being burnt causing headlight problems.
Old 14 Nov 2017, 02:56 pm
No, I hadn't considered that.
Because it's on the same circuit.
Okay, I'll search that. Keep in mind I'm new to the forum. Tried searching for hi beam issues without much luck before I made the first post
Old 14 Nov 2017, 03:14 pm
This information came from page 779 of the 01-04 shop manual. 2005 pt cruiser should be the same with this shop manual.
The left high beam head lamp has G103 ground.
The right high beam head lamp has G104 ground.
If it was a ground problem it would be only on one high beam head lamp. Not both. I can't see both grounds going bad at the same time.
Old 14 Nov 2017, 04:26 pm
Both are fed (+) from the same circuit (there's only one switch that turns it on the high beams), and that's why I came to that conclusion. If one ground is out (regardless of # of grounds), still breaks the circuit. But hey while you have the shop manual open, does it say exactly where it's located, or if I need to go from underneath the wheel well to get to it? That's what I asked in the earlier post anyway.
by pass hi-beam fog-lamps interlock _PTGT03 Tech & Performance Forum 6 01 Feb 2017 02:35 am
Newbie intake issue... j0e Tech & Performance Forum 14 04 Oct 2012 06:55 pm
Oil light issue...help a newbie girl out! sevans1975 Tech & Performance Forum 12 29 Jul 2012 09:45 pm
Newbie with a question and possible heating issue mopardude Tech & Performance Forum 6 08 Mar 2012 06:01 am
Newbie Suspension Issue & Kit advice Sarasmiles Wheels, Tires, Suspension 12 27 Sep 2009 11:59 pm
