Giving Up!
Like Tree9Likes
Old 15 Nov 2017, 10:15 am
Unhappy Giving Up!
2006 Cruiser...my mechanic has had it for 2 months and cannot figure out why it JUST won't crank. He's checked everything - coils, fuses, ignition etc, including trying a new computer and still no spark. At this point I can't afford to take it to a dealership or another mechanic. Is it worth it to try and sell as non-running because of electrical/ computer issues? And what would I even sell it for, amount-wise?? The engine, body, timing belt etc are all otherwise in perfect shape!
Old 15 Nov 2017, 10:41 am
Default Re: Giving Up!
Is it too late for us to give you some suggestions to get the Pt Cruiser running again?
Has the ignition switch been checked? Sometimes there is a pin inside that breaks.
Old 15 Nov 2017, 11:12 am
rsrocket1's Avatar
Hello Callie,
"No crank" is too broad. From your other statement "no spark", it sounds like the engine does turn but does not start (yes/no?). But when you say "no crank", that implies the engine is not even turning over which means the starter motor isn't doing its job.
Your mechanic ought to be able to at least tell you what is working i.e. the starter is good, the fuel pump is working, ignition current is getting to the spark plugs, the timing belt is intact and working. He ought to also be able to pull codes from the OBDII port if the computer is working.
If he can't figure this out, a $100 diagnostic from a dealership might be worth it, but if you can't even afford that, maybe you can offer it up for $500. Someone will jump on it and probably be able to figure it out and have a nice car for very little money if he/she is willing to work on it rather than have a mechanic work on it. For you, it might not be wort the trouble to spend between several hundred to a couple thousand dollars to have a second car that you won't be able to recoup your investment in as a resale car.
Old 15 Nov 2017, 11:20 am
oldthom's Avatar
If you can hear the fuel pump when you turn on the key that is a good sign that the computer is awake. There has got to be some codes in there to work with. This could be as simple as a bad ground that your mechanic hasn't thought of yet...
2004 LE "Dolly" 61K miles
Old 15 Nov 2017, 11:30 am
rckstein's Avatar
Welcome to the forum
What kind of "shop" has been working on it up to this point, what is their skill level?
Has the timing belt been replaced at sometime in the past?
Old 17 Nov 2017, 09:58 pm
WrenchnIswhatIdo's Avatar
Callie39 sorry to hear that
I on the orther hand I will not give up Not just yet
Question Tho
Did you Mechanic change out your crankshaft sensor.?
or The camshaft Sensor.?
.................W...........
Originally Posted by Canadian Moose View Post
Just answer one simple question. Do you own any of the following?: Opel, Alfa Romeo, Fiat, Lada, Yugo, Kia, Daewoo, Volvo, SAAB, Jaguar, Land Rover, Chrysler, Dodge, Plymouth, Jeep, Lancia.
If you answered “yes” then parts car is a really good idea.
Old 17 Nov 2017, 11:22 pm
Newbie aboard HELLO..
Find a service shop that at least knows how to use a scanning tool , compression tester and digital volt ohm meter!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
rsrocket1 likes this.
Old 18 Nov 2017, 03:32 am
I was recently called by a lady about her Cruiser that would not start, I stopped by to see what had been done,
dealer said ECM-cam sensor-crank sensor,,, starting fluid in intake, it didn't have chipped key,, since it was to cold for me to stand there and check things,
I offered a used coil since it was out of sigh -out of mind.
Next morning he stood smiling at my front door with the cruiser idling on the street..
Keep trying... They probably thought I was pretty smart
I think it was luck
Busted_PT likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 18 Nov 2017, 10:53 am
I think it was luck
I see you have one of those special tools as do I...
Old 18 Nov 2017, 11:18 am
Azrak's Avatar
Is that a dealership only tool?
2005 Touring Convertible - 2.4L I4 DOHC 16V Turbo Engine - 4-Speed Automatic Transmission.
LT. Almond Pearl Metallic Clear Coat - Black Cloth Top.
Cloth Low-Back Bucket Seats - Dark Slate Gray.
Giving your PT Cruiser a name Cruiszr General PT Cruiser Discussions 4 15 Jun 2012 06:06 pm
Giving Up the PT for a while Turbo Tommy General Turbo Discussions 10 01 Mar 2004 09:46 pm
Giving Vin# to DC for Stg. I kit, No Worries tthrift Turbo Performance 5 28 Jun 2003 06:01 pm
