2002 PT Cruiser Limited,what next...
Like Tree7Likes
  • 1 Post By kurabess
  • 2 Post By Handy_Cruiser
  • 1 Post By ptcruisersteve
  • 1 Post By NitroPT
Closed Thread
Old 15 Nov 2017, 09:19 pm
Default 2002 PT Cruiser Limited,what next...
Purchase this beauty few days ago.
Per Vin check mostly all info. seems to be
correct.
95K. miles,hard to believe but what is on the the speedo.
Drove for few days,seem like 99% solid.
No issues,except very slight body vibration.
My question would be mechanical priorities to bring
this PT to reliable state.
From what I read so far parts replacement should be
Changed timing belt, w/pump and tensioners. Replace Radiator, Starter, Alternator. Wheel bearings, Make sure you get the tapered bearings over the ball bearings.
What would be members advice, please add if I overlook something.
Thank You.
Jack.
Carnut likes this.
Old 15 Nov 2017, 09:35 pm
Default Re: 2002 PT Cruiser Limited,what next...
If it's never been done the timing belt kit is just about do. My owner's manual suggests it be done at 102,000 miles. That's not written in stone, but, between now and 102 thousand would be a good idea, along with a full radiator flush, thermostat, etc. Have the serpentine and other belt checked. Center motor mount replaced as P.M. Perhaps, a good tune-up and oil change. Have your mech go over the rest of the car and make suggestions.
Enjoy your Cruiser!
Old 15 Nov 2017, 09:53 pm
rckstein's Avatar
Welcome to the forum
Add cam and crank seals to your list while the area is torn apart.
Please post some pics of your PT
Old 15 Nov 2017, 10:08 pm
I just put in a turbo Airtex water pump on my N/A 2007 Pt Cruiser when I changed my timing belt recently. I don't recommend a timing belt kit as there is always a different preferred brand for some of the components.
There are several reasons to look at an Airtex water pump. Improved casting over other brands including OEM, less frictional fluid drag, timken bearing and seal. Proven engineering design to lower the chances of high RPM cavitation and improved water flow volume. This turbo water pump fits my Pt Cruiser.
Old 15 Nov 2017, 10:20 pm
Handy_Cruiser's Avatar
Welcome to the forum from the great sovereign state of Arkansas!
As already mentioned, do the timing belt job first. My choice is a timing kit from Gates. The best price will likely either be Rock Auto or Amazon. Your 2002 will use the older style "grenade pin" tensioner. That's good. There's little advantage to the 2003 and up tensioner and the 2001/2002 tentioner is much easier to install because there's no adjustment. Do the plug wires too if they've never been done. The plug wires on the early PT's are kind'a crappy and can make the engine run rough.
Overall, your 2002 PT is an "early PT". While we says it's a 1st Gen PT (2001 thru 2002) based on looks, the 2001/2002 PT's have some important difference in the engines and PCM's (computers) of the later models.
For other modes and things to fix and/or add to your 2002 PT, here's a PARTIAL list of everything i did to my 2001 PT. Some are repairs and many are mods. The best stuff is in bold:
NKG Iridium Spark Plugs
8 mm Plug Wires
Valve Cover Gasket
Flushed cooling system and added modern antifreeze
Thermostat
Tailgate Hatch Gas Lift Supports
New Keyless Entry Remote
2004 OEM RB1 Nav Stereo Head
2004 Chrylser LHS OEM floor mats
iPod Auxiliary Input
OEM Satellite Radio Reciever
Stereo Multiplexer to run both sat receiver and aux input
Both Rear Brake Taillight Housings
New Rubber Antenna
Left Front and left back window lift motors
Complete salvage sunroof assembly
Power Window Switch
Rear Wiper Grommet, nuts, bolts, plug
Salvage steering column
New hood prop rod
New front brakes
New drive belts
Custom K&N Style Air Filter
NOPI Twin Strut Tower Bars
LED Light Repair to Power Window Switch
Designed and performed aluminum can repair to the fog light switch
OEM Chrome Base Ball Shifter from 2004 turbo PT
OEM silver accelerator and brake peddles from 2004 turbo PT
Installed new dash, mixed paint to match original W8 taupe color
Replaced pealing center dash bezel.
Installed missing underseat drawer on passenger side
Mounted underseat drawer on driver side
Installed OEM wing on rear hatch
Cabin Air Filter
Reburbed ECM to eliminate P0601 code
Replaced missing owner's manual
Replaced bad left rear speaker
Chrome tire valve covers and caps
Salvage alternator off much newer low-mileage PT
Low Profile Vauxhall Corsa rear window wiper
Battery trey and support arm (off low-mileage PT)
Chrome door lock pulls
Small Chrysler wing emblem for vanity cover
New OEM 80-watt Mopar Subwoofer for PT
DEPO Custom backup lights
Stereo Antenna Booster
Polished Aluminum cover for decal on cargo shelf
2nd New Fob (Remote)
GT Speedometer/Gauge Cluster (did not work)
Rear Axle with Disc Brakes
myckee and kurabess like this.
Old 15 Nov 2017, 10:54 pm
Be careful of the Gates pump. One member had them fail after aprox. 14 months. he was upset he had to take it apart again after 10K miles.
Gates pump failed in the link below.
Water pump any to avoid ?
767skyking likes this.
Old 15 Nov 2017, 11:11 pm
Yes. And there's horror stories about Airtex all over the internet. The truth is that it's always possible to get a bad pump even from a premium brand. But since you can have Gates quality for only slightly more than the discount brand, Airtex, that's the way I'd go. While no brand can claim no failures, a quality brand such as Gates is till better assurance.
But I will say that Airtex seems to be getting better. The only problem is that they outsource from several different Chinese factories. So it is going to be hard to say if the Airtex pump you used last year will be the same as the one you buy today.
Like with most auto parts, we all have our preferences and our pet brands. But I've found gates to be one of the best when I can get it. It's a nice kit too with everything you need, all gaskets and even a sticker to put under the hood showing when the timing belt job was done.
Old 15 Nov 2017, 11:15 pm
What? No link to back your story? You are discounting a member of this forum with his problem with Gates water pump?
Old 15 Nov 2017, 11:18 pm
Thank You for replies.
Noted All of the suggestions.
Will post shortly follow up
on my PT.
Thank You once again for
all of suggestions.
Jack.
Handy_Cruiser likes this.
Old 15 Nov 2017, 11:21 pm
Car Repair Advice Forum= at your own risk
Closed Thread
2002 PT Cruiser Limited bubba_1952 Members PT Project 4 24 Mar 2016 10:51 pm
Code P0841 - 2002 Limited Cruiser GoldCruiser02 Tech & Performance Forum 4 11 Sep 2014 09:02 am
2002 Dream Cruiser & Limited Brochure tpsfoto Classifieds: For Sale/Trade 2 13 Jun 2012 09:01 pm
Parting out 2002 PT Cruiser Limited in SF Bay Area hawgbelly Western PT Forum 6 11 May 2011 11:35 am
FS - 2002 PT Cruiser Limited Edition - $2k slebo3213 Classifieds: For Sale/Trade 1 07 Jun 2010 10:43 pm
