MY Cruiser is Driving me nuts!!!! Please help
Like Tree10Likes
Old 20 Nov 2017, 02:24 pm
Exclamation MY Cruiser is Driving me nuts!!!! Please help
Hello,
This past January (against my father's opinion. He use to work for a chrysler dealership) I bought the car I've always wanted. A 2005 PT Cruiser. This car has been a pain in the rear since I purchased it. It has 147K miles on it. My check engine light is on but its because my o2 sensor is going bad. Over the past month the liftgate kept popping open on its own so I unplugged the electrical switch under the back panel in order to only be able to open it manually with the key.That solved that problem. Its gotten cold over the past couple of days and the battery has kept dying every time I turn it off. So today I purchased and replaced the battery. Problem solved.
The only problem I cannot figure out is that randomly while i am driving I hear a singular chime with no warning lights on the dash lighting up. Its driving me nuts. I read that it was possible that it could be saying the battery was bad, but it has done it today since I have changed the battery in the car. I have no clue what it could be. I wear my seat belt. All my doors are shut including the lift gate. Oil pressure is good. Tire pressure is good. No leaks, not overheating. I'm at a complete loss.
the only feasible explanation i can come up with is that i have stuff in my passenger seat but I would have thought that the seat belt light would come on. I need suggestions. I cannot afford for a major issue to come up with the car and would hate to end up broken down at school or on the road at night after i leave school.
Any suggestions
Handy_Cruiser likes this.
Old 20 Nov 2017, 02:55 pm
Handy_Cruiser's Avatar
Default Re: MY Cruiser is Driving me nuts!!!! Please help
Welcome to the forum from the great sovereign state of Arkansas!
If me, I'd fix both the rear hatch and the oxygen sensor first and then worry about the chime.
The hatch problem is very common and is often caused by the pressure switch going bad. This is an easy inexpensive fix where you replace the pressure switch with a universal button switch. Here's a link to a thread on this:
Liftgate touchpad replacement
For the oxygen sensor, what code are you getting? This is important and will help determine if it's really the sensor or not. Let us know the code and we can help you.
Fix these things first and then see if the chime goes away. If not, we can work on that then.
PS: If you need a copy of the service manual for your car, you can download if from my Google Drive here:
https://drive.google.com/file/d/0B9C...ew?usp=sharing
Old 20 Nov 2017, 03:26 pm
rob302's Avatar
nuts you say? the warning chime buzzer driver annoyer apparatus is located inside the instrument cluster. if you work fast, it takes about 30 minutes to remove and reinstall. it is best removed like a loose tooth. just grab it with a pliers and twist/pull.
i have circled it here in red:
it could possibly be dinging to warn you to look at your gauges/idiot lights. it is possible that the Oil light or check engine light or some other light is coming on but the previous owner removed the bulb to fool the buyer. perhaps stare at the dash while you turn the key and verify all the idiot lights are working... ...or crack it open and murder the buzzer
Old 20 Nov 2017, 03:46 pm
rckstein's Avatar
Before you do any dismantling, you may want to stop by any auto parts store and have them do a code read to verify that your PT has no pending codes, it's free.
Some people have been known to cover the CEL with either a piece of electrical tape or sharpie it over, rather than fix any issues in order to sell it. There has to be a reason for the chime sounding
When you get a chance, please go to Welcome New PT Cruiser Members - PT Cruiser Forum and create an intro thread.
Old 20 Nov 2017, 04:14 pm
To answer the question you were asking about the chime issue the PCM will send a single chime if the ignition is on "run", vehicle speed is present, and one of the doors is open. Check to make sure all the door switches are good.
Old 20 Nov 2017, 04:34 pm
Steve makes a good point.
And if this is the case, you will either have the word "Door" illuminated about the odometer and/or the rear hatch warning light will be on above the fuel gauge. It will play havoc with the dome light as well. If you don't have any of that going on, it's likely something else such as simply a chime letting you know the Check Engine Light is set. This is why you should concentrate on the things you know are wrong first.
Old 20 Nov 2017, 04:47 pm
Old 20 Nov 2017, 05:04 pm
I was just going to say it's the chime that lets you know the check engine light is on! Even an old idiot like me knows that!
Old 20 Nov 2017, 05:28 pm
If you look at the shop manual the only single chime mentioned is with the door open so wouldn't take much time to check the door switches.
Old 20 Nov 2017, 06:18 pm
Maybe the hood is ajar.
CEL Driving me nuts! mikksue Tech & Performance Forum 11 07 Jun 2016 09:03 am
Idle problem driving me nuts .. peterk General PT Cruiser Discussions 23 08 Aug 2013 04:35 pm
Serp driving me nuts... Notmycruiser Tech & Performance Forum 5 30 Jul 2013 12:37 pm
'03 Non-Turbo Driving Me Nuts!!!! GaryD Tech & Performance Forum 3 04 Jun 2010 06:34 pm
Overheating Driving me nuts sandyltn12 Tech & Performance Forum 7 28 Mar 2010 11:08 pm
