Cooling fan
Like Tree4Likes
Old 26 Nov 2017, 08:52 am
Default Cooling fan
Since the cooling fan for the engine doesn't run when the A/C is on in my PT, i measured the connection on the fan over the black/green which was "infinite" while the black/yellow gave about 2,6Ohms.
I guess black/yellow is for engine cooling, while black/green seems shot and most likely for the A/C. Is this a common problem and how should it be fixed?
Old 26 Nov 2017, 10:19 am
LionPT's Avatar
Default Re: Cooling fan
Have you checked the relay..??
oldthom likes this.
Old 26 Nov 2017, 12:06 pm
rsrocket1's Avatar
I believe you have an 2003 2.0 correct?
Page 8W-42-6 of the 01-04 service manual shows that the 3 wires going to the fan motor are:
1. Low Speed - Dark Green
2. High Speed - Yellow
3. Ground - Black
If you have 2.6 Ohms between the Yellow and Black wires, it means your High Speed fan ought to work. If you have an open connection between the DG and Black, the low speed will not work. Most likely the low speed brushes are worn out.
If you lived in the US, you could just order a new fan from Rock Auto for $50-$80 or just the motor for $48-$55
I don't know how difficult it is to get a replacement where you live so if you must rebuild the motor (replace the "brushes" which are actually copper bars), follow this link:
Radiator Fan Motor Replacement
Interesting thread and maybe a fun little project.
Old 26 Nov 2017, 01:41 pm
I would suggest applying 12 volts to both speeds on the radiator fan to verify the radiator fan needs to be replaced. It's very common for the low speed on the radiator fan to go out.
Old 26 Nov 2017, 01:56 pm
3. Ground - Black
Interesting, are you saying there are separate brushes for high and low speed?
Old 26 Nov 2017, 04:47 pm
LionPT's Avatar
Yes....read the link below.
New here....and a question
Old 27 Nov 2017, 06:39 am
Which relay are we talking about and where is it located?
Old 27 Nov 2017, 08:41 am
rsrocket1's Avatar
Since you already disconnected the fan plug, why don't you simply apply 12 volts across the pins to see if the fan spins?
Use insulated clips so you don't short them out and use at 12 gauge wire to carry the current (although you can get away with smaller gauge wire if you test for only a couple of seconds). It sure appears as if your low speed brushes are worn out.
Old 28 Nov 2017, 06:52 am
Just bought 4 new brushes which are 1mm to big 8*10 mm instead of 7*10 but only 18 mm long so i have to adjust them on the side instead of the length compared to the picture in this forum. How hard is it to dismantle the engine once you get the fan out?
Old 28 Nov 2017, 08:56 am
Wouldn't it be easier if you got some brushes that had the correct width and the length a little long? How are you planning to get it to the correct width?
cooling fan wlwhockey101 General PT Cruiser Discussions 2 02 Mar 2016 11:00 am
Cooling Fan aubert1541 General PT Cruiser Discussions 3 15 May 2015 10:46 am
Cooling Fan donsr1964 General PT Cruiser Discussions 3 05 Sep 2013 06:36 pm
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
A/C not cooling at all bigjoe1651 Tech & Performance Forum 5 10 Oct 2009 02:42 pm
