Tranny some times stuck in low gear. Codes P0700, P0870
Old 26 Nov 2017, 08:16 pm
Default Tranny some times stuck in low gear. Codes P0700, P0870
As stated some times I start car and pull out of driveway and it will not shift out of low. Shut it off and sometimes starts working fine. Getting codes P0700, Control System and P0870, OD Pressure Switch Circuit. Do I need input and output speed sensors? Transmission Module? Or all three.
Old 26 Nov 2017, 09:02 pm
Default Re: Tranny some times stuck in low gear. Codes P0700, P0870
P0870 - A/T Hydraulic Pressure Line Malfunction
Trouble Code Conditions: Engine started; vehicle driven at over 1000 rpm, then immediately after a shift, the PCM detected a malfunction in one or more of the Pressure Switch circuits (it detected the switch did not close twice). DTC P0944 may be present.
Possible Causes:
1. Check for related line pressure trouble codes
2. Check for related speed ratio and pressure switch codes
3. 5v supply circuit is open or is shorted to ground
4. Transmission Control Relay output circuit is open
5. OD Pressure Switch sense circuit is shorted to ground or to voltage
6. Excessive debris in the oil pan
7. Line pressure Sensor connector is loose or damaged
8. Oil pressure switch is damaged or has failed
9. Intermittent wiring or connector problems exist
10. PCM or TCM has failed
One member was able to fix this P0870 on his 2003 Pt Cruiser with a new automatic transmission control solenoid.
Transmissions Codes P0700 & more Nvizn Tech & Performance Forum 14 18 Jun 2017 07:28 am
2005 Auto 2.4L Stuck in 1st Gear SuzaMan General PT Cruiser Discussions 4 15 Jul 2015 06:55 pm
P0700 and p0822 codes limp mode Ghostsamurai25 Tech & Performance Forum 15 25 Jul 2014 04:50 pm
Did Transmission Fluid Change...Now Its Stuck On 1st Gear sirminder Tech & Performance Forum 25 28 Jun 2011 02:42 pm
2007 PT Cruiser: OBD Codes: P0700, P0750, and P0463 Topgear Tech & Performance Forum 5 17 Jun 2007 05:07 pm
