Crazy instrument cluster.
Like Tree6Likes
  • 3 Post By myckee
  • 1 Post By ptcruisersteve
  • 2 Post By Grasshopper77
Old 28 Nov 2017, 04:36 am
Default Crazy instrument cluster.
We have a 2009 PT Cruiser which has, periodically, been exhibiting strange behavior. *Hopefully, some of you good folks, here, can enlighten matters for us.
There are times, when I'm driving along, that all six of the LED indicators (bottom of the speedometer window) will flash on. *Typically, they will be illuminated for no more than about five, or six seconds, or so. *Five will go out, at that time, with the seat belt indicator always remaining on for a few seconds more. *Each time, when this happens, the speedometer & RPM needles will drop, and quickly move back up to where it initially was. *Twice, I noticed that the car felt like it was, temporarily, in neutral. *
Before taking it to the shop, I hope that someone might be able to give me a 'head's Up' on this. *This thing has me totally flabbergasted.
Advanced thanks,
Nathan*
God Bless,
Nathan
(2009 PT/ non turbo/auto)
Old 28 Nov 2017, 10:01 am
Default Re: Crazy instrument cluster.
Advanced thanks,
Nathan*
The link below might be a clue to the issue you are having. There is an connector below the Instrument Cluster that goes bad.
Old 28 Nov 2017, 10:26 am
While its not a bad idea to check the connector, the fact that the engine is cutting out and then coming back online, is not going to be related to that connector. It is usually an indication that there may be a problem with the power or ground connections. Since they run through the TIPM, Totoally Integrated Power Module, often it is this TIPM that ends up being the problem.
Check all of your power and ground connections. If all are okay, then you are probably going to be looking at a TIPM replacement. The loss of gauges and engine cutting out are classic signs and there have been many posts here on the forum attesting to that.
Old 28 Nov 2017, 10:35 am
This is good information above and it reminds me that it would be a good idea to have a battery load test done as Myckee posted about the power. Sometimes the TIPM does not like it when the battery voltage is lower than the norm. When was the last time the battery was replaced?
Does the radio also cut out when this happens? If so you might want to look at the ignition switch.
Grasshopper77 likes this.
Old 28 Nov 2017, 01:21 pm
I agree with getting the battery tested. I've experience almost the same symptoms (Dummy lights, RPM and Odometer needles dropping to zero, and temp power loss). Cleaned the battery terminals and replaced battery. Symptoms haven't returned in over a year.
Old 29 Nov 2017, 05:04 am
My thanks to everyone who responded.
But in answer to your question, Steve - no, I don't recall the radio dropping out, when these issues occurr.
We bought this car from my wife's aunt, and (at that time) it just had 25k miles on it. She said that she'd put a new battery in it, and the car now has 55k miles on it. It hadn't occurred to me that the battery might be having issues, and I WILL get the suggested testing performed.
God Bless,
Nathan
Could it just be the instrument cluster? ukbeachbum General PT Cruiser Discussions 21 17 Sep 2015 08:50 pm
instrument cluster bulbs rob342 Interior Accessories Forum 34 30 Aug 2015 06:22 pm
Instrument cluster goes dead kwells44 Tech & Performance Forum 5 02 Dec 2012 06:08 pm
Dead Instrument Cluster JohnBrehm General PT Cruiser Discussions 0 09 Jan 2011 10:16 pm
Instrument Cluster Lights kappa_kruiser Tech & Performance Forum 1 22 May 2008 01:03 am
