Tire pressure losses.
Like Tree2Likes
  • 1 Post By rob302
  • 1 Post By VsandFords
Old 29 Nov 2017, 11:17 am
Default Tire pressure losses.
Our 2009 PT Cruiser causes suffrages of frequent needs for inflation of its tires. *The previous owner (wife's aunt) had revealed how she had to, often, inflate tires, due to their premature air losses. *It isn't the tires, themselves, because - early last year - we had new tires installed, and the same frequency of that problem didn't fail to exist.
It had, more recently, been mentioned that the aluminum wheels were (most likely) not allowing the tires to 'seat' properly. *Now, I'm wondering if I should look into investing into a set of steel wheels - providing that those types are still being manufactured.
Or, might there be some other type of action which would prevent this issue from happening?
God Bless,
Nathan
(2009 PT/ non turbo/auto)
Old 29 Nov 2017, 11:22 am
rsrocket1's Avatar
Default Re: Tire pressure losses.
You could do the old fashioned soap bubble test.
The worst part is that you would need to take the wheel off the car to test both sides. Get a squirt bottle, fill it with a very dilute soap solution and squirt it around the rim and look for bubbles. If the wheel is laying flat on the ground, it would be more obvious because the soap solution would be sitting all around the rim.
Old 29 Nov 2017, 11:33 am
rob302's Avatar
don't forget to spray around the valve stem. IIRC the chrome rims corrode there and leak, and there's no good fix other than replacement
rsrocket1 likes this.
Old 29 Nov 2017, 11:37 am
rob302's Avatar
if it's just 1 rim you could most likely remove the tire from the rim, grind off the corrosion with a blending wheel, and use upgraded valve stems such as these along with the edge sealant:
https://www.summitracing.com/parts/b...EaAkN-EALw_wcB
IIRC we get steel rims in the PT size for ~$25 from stone wheel inc. they don't sell to the public though so you'd need a shop to order them
Old 29 Nov 2017, 11:47 am
Regardless of what you drive....as you mention ^^^^
TAKE IT BACK to the tire store or service shop and have them find the reason for your slow loss of air in the wheel/tire combo.
Slow leaks are not necessarily uncommon and sometimes hard to find without removing the tire from the rim and inspecting the inside of the wheel.
There are DIY ways to at least see escaping air but even this requires a tub to completely submerge the tire/wheel combo and to increase the tire pressure to the maximum levels.
Some of you that ever worked at a Tire shop may remember those nasty water filled tubs that always smelled like a 3 week old unwashed jockstrap to test for leaks?
Old 29 Nov 2017, 11:59 am
Those type you are talking about ( I have them and others) should come with warning and complete idiot proof instruction. ^^^ many tire "techies" don't know how to install them correctly and the they will fail at the worst times.
Most of the time I still prefer the old fashion rubber type.
Old 29 Nov 2017, 01:46 pm
VsandFords's Avatar
I had tires installed on my cruiser a couple of months ago and one was loosing air. Took it back and the tag with the barcode, in the bead was causing the leak. They removed it, cleaned the rim and brushed on a sealer. No charge.
NitroPT likes this.
Old 29 Nov 2017, 02:06 pm
As others have mentioned, it is most likely due to corrossion or gunk build-up on the rim. Usually, on the back side of the wheel. After several tire changes and years of use, the bead area tends to build-up with gunk and rust. Most tire places focus on the outside of the wheel and hardly ever clean the bead area on the back side. I'd remove the tire and dunk it in a kiddie pool with enough water to cover the tire all the way up to the wheel and start rolling the tire until you see the bubbles. Mark the leak and take it back to who ever installed and have them remove and clean the wheel.
Tire Pressure TaylorMade General PT Cruiser Discussions 15 10 Oct 2013 10:08 am
Tire pressure. Door or tire? Cliff5550 General PT Cruiser Discussions 25 27 Apr 2013 04:29 pm
Tire pressure 1lowufo Tech & Performance Forum 2 10 Mar 2010 09:23 pm
15" tire pressure? Brad Vandrasik Wheels, Tires, Suspension 6 03 Dec 2003 11:22 am
Tire pressure lip General Turbo Discussions 2 10 Aug 2003 06:38 pm
