Newly Purchased 2010 PT Cruiser
  • 1 Post By rsrocket1
Old 06 Dec 2017, 01:35 am
Unhappy Newly Purchased 2010 PT Cruiser
Today i just purchased a 2010 Pt Cruiser from a small dealership. I live about an hour and a half away from where I bought it. The car is in really good shape for the most part and has about 148,000 miles on it. On the way home, I noticed that when I try to go above 60mph it has troubles shifting. It will make a noise like the engine is struggling. I have to release the gas and it will try to shift and eventually it will start to go faster. However this is extremely troubling to me, as my thoughts immediately go to the transmission being bad.
Basically what I want to know is, does it sound like the transmission is failing? Have I just been completely ripped off?
Old 06 Dec 2017, 01:39 am
Default Re: Newly Purchased 2010 PT Cruiser
Welcome to the forum.
Is the engine light on? It might be the camshaft sensor but it should trigger engine code.
Old 06 Dec 2017, 01:41 am
Thanks! I'm so happy this forum exists.
And no, no warning lights come on at all. The only light on the dashboard seems to be an airbag light.
Old 06 Dec 2017, 01:51 am
If no engine trouble codes I would suggest you take it to a transmission shop that will check the Pt Cruiser for transmission codes for free. This will be the first step to determine if the transmission is causing the problem.
I would think about taking it back after you find out what the problem is to see if a deal can be worked out on the cost of the repair.
Old 06 Dec 2017, 07:44 am
rsrocket1's Avatar
...and that airbag light should be checked out by someone who has an SRS scanner. It's not the same as the generic OBDII scanner. It might not be a difficult fix, but you don't want to mess around with sensors and harnesses that could potentially set off the airbags unless you know what you're doing.
This is a safety issue for the driver or passenger and should also be negotiated with the dealership.
ptprice likes this.
Tags
help me, issues, transmission, troubleshoot
Just Purchased My First Car 2006 PT Cruiser ajhockey3 General PT Cruiser Discussions 11 26 Oct 2017 02:21 pm
Issues with cruiser I just purchased. Tbrown Tech & Performance Forum 6 29 Jul 2014 10:02 pm
bumpy road with newly purchased 2001 pt cruiser limited mrstolleson Tech & Performance Forum 9 08 Jul 2014 08:48 pm
02 pt cruiser, just purchased, no oil pressure 71cuda2 Tech & Performance Forum 23 28 Apr 2014 06:00 pm
Newly purchased 2003 PT Cuiser Turbo ptbetty Tech & Performance Forum 3 14 Jun 2010 02:34 pm
