2005 Pt Gt HO - Low clutch release
  • 1 Post By rob302
Old 15 Dec 2017, 02:31 pm
jallen1026's Avatar
Default 2005 Pt Gt HO - Low clutch release
Hi all,
Second post in the past week, having some really bad luck..
Driving today and the car was idling a little rough. Got to red light and I couldn't get it into gear on green. I eventually slammed it in there and took my foot off the clutch about 1cm and it started pulling forward. Had to rev match to shift to 3rd until I found a parking lot to pull into. Shifter cable and clutch have been replaced in the past 15000 miles.
Thinking slave cylinder but can't find any info on the turbo version and how it's fluid works. Any info is appreciated!
2005 Pt Gt Convertible
5-Speeeeeed
Every Grandma - "That's a sweet ride!"
Old 15 Dec 2017, 02:34 pm
rob302's Avatar
Default Re: 2005 Pt Gt HO - Low clutch release
There is an adjuster under the dash. I think it's 8mm. Loosen it, pull the pedal up and lengthen where the adjuster is, them tighten.
This is the only free option and I recommend you try it first
jallen1026 likes this.
Old 16 Dec 2017, 02:31 pm
_PTGT03's Avatar
very likely the pedal to rod attachment clamp is damaged, it's only cheap plastic and easily fails. there is a machined aluminum piece with a bronze bushing available from modern performance.
Old 20 Dec 2017, 11:01 pm
jallen1026's Avatar
Well it's kind of a funny fix. After getting it towed and searching for hours of possibly causes, turns out there was air in system small clog in fluid lines?
Now back to oil cooler/cooler line leak :/ never ends with this car....
5-Speeeeeed
Tags
clutch, low release, shifter cable, slave cylinder
2005 trunk release handle DannyP1317 Exterior Accessories Forum 6 25 Jul 2017 07:58 am
MT Grinding on RELEASE of Clutch Pedal ColoPT Tech & Performance Forum 12 22 Feb 2015 11:08 am
needed, electrical schematic for 2005 PT rear hatch release ptprice Tech & Performance Forum 12 18 Dec 2014 12:24 am
2005 PT With a Worn Clutch PTDAN Tech & Performance Forum 17 26 Mar 2007 02:26 pm
Clutch release delay sca037 General Turbo Discussions 5 28 Nov 2005 09:58 am
