Im runnng hot and cant stop the leak....
  • 1 Post By ptcruisersteve
Old 17 Dec 2017, 06:10 pm
Default Im runnng hot and cant stop the leak....
So about a week ago there came a bad noise from the engine. I light grumbling that I associated right away with a water pump. Sure enough three days later it is leaking like a faucet from the water pump area. So I went and got the kit and today I replaced the water pup. t-belt, etc. The pump would not spin freely, it definitely was bad.
Put it back together and it is STILL leaking from the same general area.
I am baffled. WTF did I miss?
Anyone got any ideas?
What should I do?
2006. 2.4 Vin Code "B".
Old 17 Dec 2017, 07:25 pm
My02RedRide's Avatar
Default Re: Im runnng hot and cant stop the leak....
What should I do?
Freeze plug pop or rust out? Water pump gasket goes on the pump body unless it moved out of the groove when you were installing the pump to the block.
Old 17 Dec 2017, 07:54 pm
How did you check for engine coolant leaks? Did you do an engine coolant compression test?
rsrocket1 likes this.
Fan Won't Stop Running jeremysaal General PT Cruiser Discussions 1 10 Jan 2012 11:00 pm
2 Questions; radiator line wrench size, stop leak. FleshEater Tech & Performance Forum 3 30 Mar 2011 01:27 pm
I can't stop, somebody help me!! Mike-in-Orange Exterior & Interior Styling 8 08 Mar 2004 04:38 am
Can't stop smiling cook General PT Cruiser Discussions 19 21 Dec 2003 04:48 pm
