Will 1st Gen Tail Lights Fit 2nd Gen?
Like Tree9Likes
  • 4 Post By chuzz
  • 3 Post By rckstein
  • 1 Post By dougs
  • 1 Post By chuzz
Old 22 Dec 2017, 01:41 pm
ajhockey3's Avatar
Default Will 1st Gen Tail Lights Fit 2nd Gen?
My passenger tail light is currently held in by silicon. My driver is pushed out a bit from I assume a previous accident that was never repaired?
Getting a different style aftermarket set (that I think looks pretty cool) isn't too expensive, only a few more bucks than used from a junkyard. I really like this set
Chrysler PT Cruiser 01-05 Rear Smoke Altezza Tail lights Pair RH LH | eBay
Lists it for 2001-2005 and not 2006-2010
My understanding was the color of the OEM ones are different for first and second gen, but are physically the same shape
So will these fit?
Old 22 Dec 2017, 01:53 pm
LionPT's Avatar
Default Re: Will 1st Gen Tail Lights Fit 2nd Gen?
The plugs are a little different..the 1st Gen has to be modified a little to fit the 2nd...so I assume there would be no problems going backward.
Old 22 Dec 2017, 03:45 pm
Handy_Cruiser's Avatar
The 1st Gen (2001-2005) tail lights with orange turn signal lenses and the 2nd Gen (2006 - 2010) tail lights with clear turn signal lenses and orange bulbs are interchangeable if you take a Dremel tool and remove the tabs in the bulb sockets. Here's the tabs in RED that must be removed:
Old 22 Dec 2017, 04:52 pm
As long as you take the wiring sockets along with the tail lights, they're plug and play. I did this on my 03 GT. I put in tail lights from an 06 PT. What I mean by the wiring sockets, is the piece between the body harness and the tail light. They're different where the bulbs plug in, but as long as you take that piece, you can plug it right into the body harness. I don't have pics, so hope you get what I'm saying. Sounds like your current lights are missing a lock tab at the top or some spring clips that hold them in. They get brittle and break off pretty easily.
Old 22 Dec 2017, 07:15 pm
rckstein's Avatar
So will these fit?
I can't find much on specs on these, but some sources say they don't include any bulbs. Don't use an LED bulb as with the CANbus electrical system in the Gen2, could result in hyper-flashing, of which you will have to install a resistor in the circuit to cure. Just use a standard incandescent bulb, not the Sylvania Long Life which burns hotter than a plain, old standard incandescent bulb. Another member had these lenses and some bulbs burn hotter than others, and they melted the lenses.
Old 25 Dec 2017, 06:50 pm
dougs's Avatar
They will fit, but Chrysler in its wisdom modified the flange alignment slightly.... but as noted on another reply, you can make them work with a little cutting of the plastic.
Handy_Cruiser likes this.
Black base 2006 NA, dented front bumper, scratched rear bumper. 2008 Touring, one of 385 red Turbos built in 2008. Limited grill, body-colored mirrors, grab handle deleted, dual-tone horn, shorty antenna.
Old 26 Dec 2017, 08:32 am
I didn't have to cut anything. Mine fit just fine.
dougs likes this.
2001-2005 New Chrome Accessories: for dash/bezel, head lights, tail lights & more mrsciguy Classifieds: For Sale/Trade 5 18 Mar 2017 06:13 pm
my door locks,head lights and tail lights don't work. bones02 Tech & Performance Forum 38 06 Apr 2016 10:30 am
Tail lights, dash lights, a/c panel lights not working ZZCruizer Tech & Performance Forum 12 14 Dec 2015 11:11 pm
No Brake lights or tail lights/running lights kitzmann56 General PT Cruiser Discussions 8 14 Feb 2015 03:07 pm
HELP! '02 Cruiser with no tail lights, then no brake lights. tschauer Tech & Performance Forum 1 16 Sep 2010 05:54 am
