Battery Light
Old 24 Dec 2017, 07:01 pm
Default Battery Light
Bear with me as I give you all the information I have.
I have an 06 touring edition with 152k miles
Note I have had to jump my car a couple times.
I've replaced both terminals due to corision.
Battery randomly comes on. Sometimes five minutes down the road sometimes twenty minutes. Sometimes not at all.
Sometimes code p063a pops up. But not always.
Taken to auto zone/advanced all check and say the battery and the alternator are good.
Placed a multimeter on them. Measures 12.4 (after charged no idea when it was dead) and between 13.5 - 14.5 when running. Sometimes it fluxes while running but not always.
When turning over I have clocked it in at 10.3, 10.1, and 9.8 this is all not having been charged since the first one.
I took back to autozone. They ran a drain test while running. Hit .69mA came up suspect. And would flux. Was never high enough to constantly be "suspect".
Disconnected the battery negative and ran a particular drain test. Radio gave fluctuation on the meter. Would start at .15 and settle at .0007
Pulled both my aftermarket rad and amp fuses finally settled at .0004
Drove the car and the check battery light still flicked on. About two minutes down the road.
I don't think it's a pcm since that shouldn't stop my car from charging and dying.
Maybe it's still a bad alternator? Battery?
Any thoughts would be helpful in diagnosis this.
Cheers
Old 25 Dec 2017, 12:19 am
Default Re: Battery Light
What year? What mileage? N/A or GT?
To help you diagnose we need this information.
2016 Kia Soul Plus Black
Old 25 Dec 2017, 02:50 am
P063A - Generator Voltage Sensor Circuit
Possible causes:
1. Faulty Alternator
2. Alternator harness is open or shorted
3, Alternator circuit poor electrical connection
4. Faulty Powertrain Control Module (PCM)
Some members have had this problem and it turned out to be bad battery cables. Check to make sure your battery cable connectors are making good contact and that the battery cables are good.
What is your battery voltage when your engine is at 2,000 rpm?
Old 25 Dec 2017, 08:53 am
I apologize slipped my mind. Updated 06 touring edition with 152k miles.
Old 25 Dec 2017, 03:25 pm
Check the ground wires and connectors on the driver side fender. This can be a problem area.
Battery Light comes on every once in a while kylepnew Tech & Performance Forum 7 27 Aug 2017 07:35 pm
battery light after new battery help! Annette Tech & Performance Forum 11 01 Sep 2016 11:03 am
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
battery light on eli PT Cruiser Convertible Forum 1 24 Jul 2011 05:17 pm
