Key In Ignition 2008 Cruiser
Like Tree2Likes
  • 1 Post By ptcruisersteve
Old 26 Dec 2017, 01:09 pm
Default Key In Ignition 2008 Cruiser
My car constantly warns me when I open the door that the key is in the ignition when, in fact, it is not. I've looked through the 2006 Manual for the schematic for the circuit that is telling my car that the key is in the ignition, but can't find it. Has anyone ever dealt with this before? Can I pull the ignition switch and troubleshoot the 'key present' switch there? Would love a schematic of this circuit to aid in troubleshooting.
Thanks,
Bandy
Old 26 Dec 2017, 02:05 pm
Default Re: Key In Ignition 2008 Cruiser
Thanks,
Bandy
How does it warn you? Chimes?
Old 26 Dec 2017, 02:07 pm
Yes, chimes and displays "Key in Ignition" in the Instrument Cluster display
Maybe there's an option to bypass it?
Old 26 Dec 2017, 02:56 pm
The link below indicates that the computer thinks the key is still in the ignition switch in the off position. I would suggest fixing this issue before fixing the fuel gauge issue. The two issues might be caused by the same problem.
In the link below stroll down to where it says "Key in Ignition warning".
Chrysler Workshop Manuals > PT Cruiser L4-2.4L (2008) > Instrument Panel, Gauges and Warning Indicators > Audible Warning Device > Component Information > Description and Operation > Chime/Buzzer - Description > Page 9552
bandersnatch likes this.
Old 26 Dec 2017, 04:52 pm
The 2006 ignition is redesigned from prior years. If you must remove the actual ignition switch you will need a 5 point star torx bit.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 28 Dec 2017, 10:57 am
can anyone find the schematic for the key-in ignition switch? I've searched high and low through the manual but can't find it
Old 28 Dec 2017, 12:46 pm
In the 2006 Factory Shop Manual under wiring 8W-13-9. #5 is key in. It shows the ignition switch wiring diagram.
Old 28 Dec 2017, 01:04 pm
I see it! thank you! should be easy to check switch function with ohm meter!
2008 PT Cruiser says key is in ignition Help! My08PT Sound and Security Forum 10 17 Jul 2019 07:11 am
2007 2008 PT Cruiser Ignition Actuator Disassembly PiedmontJim PT Cruiser Videos 3 02 Jul 2017 07:43 pm
2008 Ignition Switch Problem PiedmontJim General PT Cruiser Discussions 4 06 Jun 2017 09:16 pm
2008 Ignition switch actuator L2fish Tech & Performance Forum 2 26 Aug 2016 04:57 pm
2008 Pt Cruiser with the ignition switch Savemoneyandmakemoney2013 Tech & Performance Forum 4 20 Aug 2013 11:33 pm
