Ignition accessory position
Old 26 Dec 2017, 09:39 pm
Default Ignition accessory position
'03 GT Turbo. Ignition key won't go into accessory position. Steering wheel doesn't lock. Both items were working intermittently; now kaput. New ignition cylinder? Possible lubrication fix? Thanks in advance.
Old 26 Dec 2017, 10:03 pm
Default Re: Ignition accessory position
You might want to check your key cylinder and your ignition actuator.
Radio works on accessory position but not run position 240zron Tech & Performance Forum 9 07 Aug 2016 08:37 am
New Ignition Switch - No Accessory Power Alynn Tech & Performance Forum 5 10 Oct 2015 03:27 pm
12v accessory help 01cruiserowner Interior Accessories Forum 2 13 Sep 2013 02:05 pm
Two Position to Four Position Power Window Switch axxsys General PT Cruiser Discussions 6 06 Dec 2008 10:29 pm
