What bit is the screw holding in the tail light
Like Tree5Likes
Old 02 Jan 2018, 07:18 pm
ajhockey3's Avatar
Default What bit is the screw holding in the tail light
I hit a bump awhile back and broke the top clip of the tail light, Just used silicon to hold it together to wait for the local scrap yard to open back up after holidays.
Silicon starting to fall apart, And scrapyard opens tomorrow
Can anyone tell me what screw bit this is? I'm clearly going to have to buy the correct tool, I tried using a flathead but it was just stripping it.
Ignore all the damn salt,Damn Canadian roads
I don't own any Torque bits other than the T55 for the engine mount
Thanks
rob302 likes this.
Old 02 Jan 2018, 07:23 pm
Default Re: What bit is the screw holding in the tail light
It should be a T27 , I tried a T25 and it was too loose. ( didn't have a 27 near by so I didn't confirm. )
My 06 also has a slot for a flat blade screwdriver, tried it but things were too tight.
VsandFords's Avatar
I think it is a T15 torx. I'm guessing though, it's too cold and dark to go out and look. Maybe I'm just lazy after a day at work.
Old 02 Jan 2018, 08:25 pm
wingman55's Avatar
I just went out to the garage and verified that it IS a T-27 Torx. The screws also have a slot for a flat blade screwdriver.
If yours is rusty at all, soak it with Liquid Wrench or P-Blaster for a few days first to avoid problems if possible.
Gkon likes this.
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
2004 Limited Edition Platinum Series, Graphite Metallic, Standard Turbo, automatic, RBQ radio with Sirius Radio & 6 CD changer, VentShades, chrome exhaust tip, door spears, grille inserts, door lock pulls, bright pedals and steering wheel spokes. Red spoiler from a donor PT. Known as: "The RATMOBILE" I bought it Apr 28th, 2016 with 62,400 miles on it.
Old 02 Jan 2018, 08:33 pm
RickinPA's Avatar
This is my go-to for Torx screws:
https://www.amazon.com/Eklind-22571-...s=torx+key+set
Since I don't encounter Torx screws too often, it's convenient to flip through until you have the right one.
Old 02 Jan 2018, 09:13 pm
ajhockey3's Avatar
I noticed this but my tail light hasn't been removed in 12 years and wants to strip with the flathead
rob302 likes this.
Old 02 Jan 2018, 09:18 pm
rob302's Avatar
I used the Flathead you might tap the screwdriver with something hammer like to break any corrosion
Old 03 Jan 2018, 12:16 am
rsrocket1's Avatar
Be very careful with the old plastic tail lights. I tried to slap the light back into the body thinking it would snap into place and the plastic shattered in several places.
That was a $27 mistake.
svtnos likes this.
Old 03 Jan 2018, 08:52 am
rob302's Avatar
I've gotten my pt airborne over intersections, jumped off 10" curbs, acted like I was a rally car sliding and scraping through trees while slamming through and around puddles, played bumpers cars hard enough to lose my plate, yet never broke a light.
What kind of bump did you hit?
Old 03 Jan 2018, 11:52 am
ajhockey3's Avatar
Yeah the clip on the top is currently broken on mine, that's why I have to replace
Brake Light Condensation/Tail Light Replacement? NewPTCruiserInPA Tech & Performance Forum 3 23 Jul 2012 09:05 pm
Need Dash Tweeters Measured Screw to Screw- MoparHemiPower Sound and Security Forum 3 13 Sep 2011 06:41 pm
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
tail light broken, but brake light works dirtydmix General PT Cruiser Discussions 8 09 Mar 2011 09:59 pm
