PT Cruiser Limited - Hard To Go Into Gear In Cold Weather
Like Tree9Likes
Old 03 Jan 2018, 02:02 am
CherylM's Avatar
Question PT Cruiser Limited - Hard To Go Into Gear In Cold Weather
I own a 2007 PT Cruiser Limited - 110k...automatic
During the past week when it has been down in the 20s, my car seems to have a hard time going into gear when it first starts. This is what happens...
I will start my car and let it run a couple of mins...then shift into Reverse to back out of the driveway. When I shift into Drive to start driving forward it will act like it doesn't want to go into gear. Then it will suddenly go into gear and I can begin to drive normally without any further problems on my 20 min/17 mile trip to work. I might add that when I get ready to drive home I don't have any problems shifting into gear at all.
Do you think this could be because of the cold weather ? I have never had this problem before. Or could this be a sign of troubles to come ? Thanks
Old 03 Jan 2018, 03:46 am
LionPT's Avatar
Default Re: PT Cruiser Limited - Hard To Go Into Gear In Cold Weather
Under the battery tray is the shift linkage...it's possible that it's getting wet & freezing or you have a tear in the rubber cable cover & that is freezing.
Old 03 Jan 2018, 07:53 pm
CherylM's Avatar
Update...today when I got ready to leave for work I decided to test my car before I left the driveway. *I backed up halfway down the drive way..put it back in drive and pulled back up. *When I tried to go back in reverse to drive all the way down the driveway...it wouldn't kick into reverse. *After giving it some more gas it eventually went into gear. *I got out in the street and tried to shift into drive..it wouldn't go into gear. *Again I gave it more more gas and it eventually kicked into gear. *I however had no further problems when going to run an errand...and eventually driving to work. *
Old 03 Jan 2018, 08:26 pm
LionPT's Avatar
Have you checked the fluid level..??
Old 04 Jan 2018, 12:13 am
CherylM's Avatar
Yes....it's right on the money
Old 04 Jan 2018, 08:44 am
Sounds to me like you need to change the filter. I'll bet it's dirty and the cold fluid is having trouble getting through it. Oh, and change the fluid too, not just the filter. ATF+4 ONLY.
_PTGT03 and the3dgm like this.
Old 04 Jan 2018, 01:48 pm
CherylM's Avatar
I saw a post on this forum from a few years back that a fellow PT Cruiser owner had the identical problem. Seems like it is related to the cold. But I am of course open to any and all suggestions.
Old 04 Jan 2018, 08:09 pm
Macgyverman1123's Avatar
Not exactly the same, but I had an old Chevy once that did just about the same thing. Turns out the speed sensor had gone bad. Not sure if these cars have them or if they operate the sane. Check for codes?
Old 04 Jan 2018, 10:04 pm
_PTGT03's Avatar
Replace your fluid as it's old. When transmission fluid breaks down, it may appear just fine but it won't work as good as it should when new, and usually the symptoms can appear in colder ambient temperatures, but as the fluid warms up, most of the symptoms will go away.
I suggest that you get some consumables from AMSOIL .
Order a bottle of AMS transmission and oil flush.
Order a transmission filter
order the correct amount of replacement oil, get the OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) which is compatible with ATF+4 specification. Good quality synthetic transmission oil is essentially good for the remaining life of an older used vehicle.
Follow the instructions on the oil flush, replace the filter, and replace the fluid. Make sure to follow the OEM procedure to fill the transmission with the correct amount of fluid and check it according to the oil line on the dipstick against the temperature of the oil.
I just had the transmission oil replaced on my 2005 dodge durango, I was experiencing rough 1-2 shifts when the engine was cold and driving heavy. Sometimes the engine would stall out after shifting from park and coming to a stop after moving ahead or in reverse. After replacing the oil, all the issues went away and it's shifting smoother than a knife through a bowl of whipped cream.
Old 04 Jan 2018, 11:14 pm
SpaceMouse's Avatar
My '66 Mustang with its rip roaring 200 cubic inch 6 cylinder and C4 three speed automatic transmission behaved exactly as you describe when its bands and clutches had worn out and its seals had petrified (i.e. the transmission needed to be rebuilt). Which may or may not be germane to what's going on with your PT Cruiser.
01 cruiser, noise when starting in cold weather kstrafo Tech & Performance Forum 6 25 Feb 2015 01:46 pm
Hard to shift into gear, worse when cold Swingingspeedy Tech & Performance Forum 29 19 Nov 2014 09:12 pm
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
2002 pt cruiser 5spd pops out of 5th gear and hard shifting bobby515 General PT Cruiser Discussions 3 03 Jun 2008 08:39 am
