Heater Issue
  • 1 Post By JDK52
Old 08 Jan 2018, 05:05 pm
ajhockey3's Avatar
Default Heater Issue
Can't find a ton of information on how to fix this.
No heat comes out of top vents, However works on defrost fine. Nob forces itself back, Even if I force it and hold it into place it doesn't put air out the top vents. When I first got the car they moved, Took a bit of force but worked. Now doesn't work at all. Here is a quick video I made showing the issue
https://youtu.be/wZYh_BXTWWY
If I buy a new set of controls from a junkyard ($20) will it fix the issue?
Old 08 Jan 2018, 09:30 pm
JDK52's Avatar
Default Re: Heater Issue
The cable has suffered a bend of the internal wire.
A new cable is a good remedy, as well as making sure the control doors that the cable actuates are not binding.
You can get to the mechanicals after removing the glove box and the mechanism cover from the side of the air distribution assembly.
The cable attachment at the knob requires the center radio fascia be removed.
If you just replace the cable and the control doors are stuck or binding the new cable will fail.
Good Luck
Old 08 Jan 2018, 09:34 pm
JDK52's Avatar
CHRYSLER OEM 06-09 PT Cruiser 2.4L-L4 Evaporator Heater-Control Cable 5179479AB
ITEM PRICE:
US $14.10
https://www.officialwholesaleautopar...waArDdEALw_wcB
Waterpump / Coolant / Heater Core Issue? No Heat... rhino169 General PT Cruiser Discussions 40 12 Sep 2017 12:23 pm
UG~! Heater Vent Control Knob Issue 2008 Sarasmiles General PT Cruiser Discussions 3 27 Jun 2014 06:44 pm
Heater Blower Motor Issue sscanlan General PT Cruiser Discussions 5 30 Aug 2011 10:50 pm
Issue with ac and heater when turn dial on. steph66 General PT Cruiser Discussions 6 06 Feb 2011 07:40 am
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
