2001 PT Cruiser wiper problem
Like Tree6Likes
  • 4 Post By sanatanadharma
  • 1 Post By chuzz
  • 1 Post By rob302
Old 10 Jan 2018, 12:20 am
Unhappy 2001 PT Cruiser wiper problem
2001 PT Cruiser......rear wiper came on when i left work Monday Thought i had hit wiper lever, but no matter what position i put selector in, it would not go off. Shut car off, back on, wiper still on. Can't shut it off. Pulled fuse #15, all wipers are off. Replaced fuse and it still cycles. No separate fuse for front and rear. Tried to pry arm off till i find cause, but wiper arm seems welded on. Don't want to break rear glass to remove it. Any suggestions???
Old 10 Jan 2018, 12:32 am
Default Re: 2001 PT Cruiser wiper problem
Open rear hatch
Remove inner plastic panel
Disconnect rear wiper motor wiring connector
Or, perhaps
Remove front center radio surround
Remove lower switch panel
Disconnect rear wiper switch
Old 10 Jan 2018, 08:24 am
ajhockey3's Avatar
Originally Posted by sanatanadharma View Post
Open rear hatch
Or, perhaps
What if he wants to use the wiper?
Old 10 Jan 2018, 08:28 am
Rear wiper is not on the wiper stalk for the front ones. It's a toggle switch on the dash under the radio. That is, if you're trying to control it with the wiper stalk. If not, then either pull the fuse or remove the toggle and unplug it.
ptprice likes this.
Old 10 Jan 2018, 08:58 am
rckstein's Avatar
You have a Gen2 where the rear wiper is on the stalk with the front wipers, the Gen1 is different.
Old 10 Jan 2018, 10:43 am
rob302's Avatar
Open rear hatch
Or, perhaps
try hitting the switch with a screwdriver handle or something similar. sounds like a stuck switch or relay. the rear wiper motors are prone to failure. failing motors tend to make relays stick. i *think* the relay for the rear wiper is part of the switch.. so tapping it may unstick it.
ptprice likes this.
2006 pt cruiser windshield wiper problem Benjamin9669 Tech & Performance Forum 2 06 Nov 2014 05:04 pm
2001 Pt Cruiser running problem ScottC Tech & Performance Forum 1 02 Mar 2013 03:19 pm
2006 cruiser rear wiper problem wherley Tech & Performance Forum 6 30 Jul 2012 11:02 pm
instrument cluster problem 2001 cruiser Mike72903 General PT Cruiser Discussions 7 17 Dec 2009 11:56 am
new 2001 cruiser.....small problem....help?? superbert1971 Tech & Performance Forum 17 11 Mar 2009 08:10 am
