Head gasket set.? 05 Turbo
Like Tree10Likes
Old 10 Jan 2018, 12:42 am
WrenchnIswhatIdo's Avatar
Default Head gasket set.? 05 Turbo
loooking for information on a good head gasket set(with bolt)
I should use on My 05 Pt cruiser turbo lite.?
.Thanks .....W...
rob302 likes this.
Originally Posted by Canadian Moose View Post
Just answer one simple question. Do you own any of the following?: Opel, Alfa Romeo, Fiat, Lada, Yugo, Kia, Daewoo, Volvo, SAAB, Jaguar, Land Rover, Chrysler, Dodge, Plymouth, Jeep, Lancia.
If you answered “yes” then parts car is a really good idea.
Old 10 Jan 2018, 08:13 am
VsandFords's Avatar
Default Re: Head gasket set.? 05 Turbo
My recommendation is to use a FelPro head set. You will have to buy the head bolts separately.
Handy_Cruiser likes this.
Old 10 Jan 2018, 08:55 am
Handy_Cruiser's Avatar
+1
I bought this exact Felpro head set for my 2005 GT. I was doing the timing belt and installing performance cams at the time, so I basically used the entire kit except for the head gasket itself. Everything was high quality and superior to OEM gaskets (or lack there of).
And yep, buying the head bolts separately is likely the best plan. For me, I look this stuff up first at Rock Auto and then figure out the price with shipping. Then I plug the part numbers into Amazon. Amazon has a terrible auto parts application system. But if you shop Amazon by part number, you can often find the same parts at the same price as Rock Auto but with free two-day shipping if you already have Amazon Prime.
044400 likes this.
Old 10 Jan 2018, 12:12 pm
rob302's Avatar
if you just put a FORD motor in it, you wouldn't have head gasket issues.
Old 10 Jan 2018, 01:06 pm
ajhockey3's Avatar
Have you not seen the Focus RS's Issues?
rob302 likes this.
Old 10 Jan 2018, 02:18 pm
rob302's Avatar
AAAAAHAHAHHAHA nicely timed
but i meant a real ford motor
see here
Old 10 Jan 2018, 02:19 pm
Why would you put sh$$ in a gold box
chuzz likes this.
Old 10 Jan 2018, 04:28 pm
Rob's right. The Ford engine will likely crack the block long before the head gasket blows.
PS: That's not saying much because the head gaskets fail on many a Ford V6 before 100,000 miles. Got a brand new motor from Ford one time over that one. And that head gasket on it blew as well.
Old 10 Jan 2018, 10:16 pm
Old 10 Jan 2018, 11:57 pm
Thanks for the feedback....
ordered
FEL-PRO ES71028 (bolts)
FEL-PRO HS26202PT (gasket set)
$91 Rockauto
I have anther issues
My #1 cylinder is at 140pis
all others@170-180
My leak down test on the head shows valve are tight (no leak down)
I think piston rings are in order I just don't want to go there because I don't think i can do that job without getting into the balancing shaft removal
So can You tell me whether or not this is true .?
Do i have to remove the balancing shaft's
to access the #1 & #2 connecting rod bolt's.?
.....Thanks ...W
'04 pt turbo blown head gasket Tayne_Hughes Tech & Performance Forum 17 10 Apr 2016 12:20 am
head gasket replacement w/turbo goodwrench67 Tech & Performance Forum 4 17 Feb 2014 08:23 am
03 pt turbo oil in water new head gasket fresh head strokedoutss General Turbo Discussions 7 17 Apr 2013 04:22 pm
Whats the Head flat spec. for head gasket. Busted_PT Tech & Performance Forum 7 26 Apr 2012 08:16 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
