Power steering woes
Like Tree4Likes
  • 1 Post By RickinPA
  • 3 Post By JonN
Old 15 Jan 2018, 10:45 pm
JonN's Avatar
Default Power steering woes
Hey guys,
Looking for some advice on a power steering issue I've been having. Occasionally at idle my power steering seems to not work and makes steering hard as hell. However, once I start moving over 10 mph steering is perfectly fine. Pump isn't being noisy, belt and tensioner are fine, and fluid level is also fine and I had my rack and pinion replaced last July.
On a hunch I figured the fluid may be contaminated, I took the good old turkey baster out and flushed out the reservoir, holy $hi+ I don't think this looks good....
For some reason my photo keeps getting turned 90° adter uploading here sorry for the inconvenience
I've flushed the reservoir once and refilled with atf+4, but the issue is still present. I'm sure I may have to flush out several times.
Other than that, anyone have any suggestions?
'01 LE 167K
Thanks
BIG RED '01 LE 190K and counting!
Vision Cross 16x7 Rims, 205/55/16 , Painted Calipers, Spoiler, CAI, Pioneer DEH-64BT head unit, NEW Skar SKv2 200.4 amplifier 2 RF P2D2 12's, RF P1T-S Tweets, RF PPS4-6 Mids, RF 6x8"s, AudioControl 24XS crossover/line driver
Newest Car
2016 Jeep Patriot Sport 2.4L 6 speed auto 86k
Powerstop Z23 evolution front brakes, Pioneer DEH-X9600BT head unit, Bē Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 16 Jan 2018, 07:37 am
LionPT's Avatar
Default Re: Power steering woes
It sounds like you have a vacuum leak somewhere...most likely at the brake booster.
I'm gonna guess the bubbles in your pic came from you putting the fluid from the baster to the bottle...but if not, you have a loose line that it letting air into the system.
Old 16 Jan 2018, 11:44 am
VsandFords's Avatar
When I replaced the power steering pump on my 01' last year, I had basically the same symptoms. When the Cruiser was not moving, it was impossible to turn. After I started moving, the steering felt fine. My assumption was the pressure relief valve had gone bad. I replaced the pump, pulled the reservoir and flushed the screen inside. Problem solved.
Old 16 Jan 2018, 01:42 pm
JonN's Avatar
I'm thinking I'll do the same when it gets a little warmer here in Massachusetts. Working on cars in the cold is no fun. I'll just deal with it until a good day comes to do it.
Also, how did you flush the screen inside?
Newest Car
#LoudLife
Old 16 Jan 2018, 02:12 pm
Does this stiff steering only occur on a cold start up? If so , this goes back to the early days of power rack and pinion. The control valving on the rack wears out the bore and causes cross leaks reducing power assist.
There are two valves in the PS pump, one is a pressure relief that noise you hear when the wheel is turned hard to one side and a flow regulator valve. The pressure relief only comes into play when the wheel is hard to one side, it will never open in normal operation.
The flow regulator valve , in part , gives you consistent rate of steering assist. It could stick but I've never verified this to occur regardless of brand.
The generally the fix is replacing the R&P , a temp fix is to use AW 46 or so hydraulic fluid but this thicker oil can cause pump noise when cold due to cavitation.
If the screen was clogged, you would get pump buzzing. My 06 at 162,000 miles has fluid that looked the same. The red dye used in ATF / other fluids turns brown normally so if the fluid does not smell burnt, it is fine.
Old 17 Jan 2018, 04:18 am
RickinPA's Avatar
Here's a video I did of a power steering flush and reservoir screen cleaning:
If you wanted to check the condition of the screen, you could probably pull the lower hose and suck the fluid out to lower the level below the screen. Then look at the screen through the cap with a flashlight.
JonN likes this.
Old 21 Jan 2018, 05:38 pm
JonN's Avatar
I've now flushed out the resevoir 4 times and the fluid looks all new now. It doesn't matter if it is cold start or not, steering is still tough at idle. I've noticed though that if I rev it to above 1000 RPM the power steering comes bacl no problem. Do you think this may suggest pump failure? If so, it's a job I'd like to do myself. If anyone has any pointers that would be great.
Newest Car
#LoudLife
Old 24 Jan 2018, 11:34 am
JonN's Avatar
I've decided I don't really feel like dealing with this, so I'll be taking to my mechanic later this week. I'll report back any findings.
Newest Car
#LoudLife
Old 29 Jan 2018, 08:53 pm
JonN's Avatar
Diagnosis came back as the pump being bad. I also had my mechanic replace all pressure hoses for peace of mind. $425 later I am back and steering is perfect.
Newest Car
#LoudLife
Power steering UwharriePT Tech & Performance Forum 6 04 Mar 2013 06:29 pm
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
Power Steering DonGee Tech & Performance Forum 3 09 Dec 2011 07:34 am
No power steering. monitor51 Tech & Performance Forum 11 20 Dec 2010 08:47 pm
Power steering ??? Hayworth Tech & Performance Forum 4 22 Nov 2009 06:09 pm
