What is it.?
Like Tree11Likes
Old 21 Jan 2018, 04:34 pm
WrenchnIswhatIdo's Avatar
Default What is it.?
I found this during my Head job on my 05 LE turbo lite
any body have any idea were it goes.?
.Thanks ................W.
Originally Posted by Canadian Moose View Post
Just answer one simple question. Do you own any of the following?: Opel, Alfa Romeo, Fiat, Lada, Yugo, Kia, Daewoo, Volvo, SAAB, Jaguar, Land Rover, Chrysler, Dodge, Plymouth, Jeep, Lancia.
If you answered “yes” then parts car is a really good idea.
Old 21 Jan 2018, 06:05 pm
Default Re: What is it.?
Did the PCV valve fall apart? Looks like the internal plunger but no spring. ( I don't know your car specifically, just going on what car parts look like )
Old 21 Jan 2018, 06:43 pm
this is about 1/2" long and smells Like a lot of miles of clean hot Lube oil
Some import engine have a orifice or needle valve/check ball to restrict flow to from the head
Some are placed in the head others are placed in the oil passage in the block..
I have never had the head off a 2.4ltr Turbo motor and hope its not what im thinking it is......W
Old 21 Jan 2018, 07:32 pm
Dig around here, it might show up on a parts list.
https://www.moparpartsgiant.com/
Old 21 Jan 2018, 09:32 pm
thanks i dig through there couldn't find it
is it a oil passage check valve.? turbo only.?
Old 22 Jan 2018, 06:34 pm
Where did you end up finding this? ( On floor , in oil drain pan , under valve cover ? )
Digging through the manual, I found a cylinder head restrictor but it is part of the head gasket ( and will just be a small hole not a valve. )
Many times under piston oil squirter have a valve that shuts them off when oil pressure drops ( at idle ) but they would be part of the squirter and a check ball / spring type of operation. This done to prevent oil pressure from dropping too much / loading the cylinders / rings with oil causing a idle oil burning situation.
I wouldn't expect plastic to be used in the oiling system especially as a regulator.
I'm still voting for PCV valve internals or maybe a shipping plug.
Old 22 Jan 2018, 06:54 pm
rckstein's Avatar
In searching the internet, I came across this pic of the internals of a Chevy PCV valve, but the second item from the left looks exactly like what the OP to this thread found.
Old 22 Jan 2018, 08:59 pm
You guys are "Money"
It fell out of the head when i was pulling it out of the car I heard it but wasn't till I was have through the torq sequence That i looked down and there it was
when i bought the car two years ago the PCV was Gutted
Replaced it and drove it....guess we found the guts worked it way pass the Baffle in the valve cover other Piece Like you shown is still in the baffle i can hear it when i shake it.....
I looked in the PCV and there it was same stamp # and all
I was hoping it was not some part of the oil feed to the head to limit oil supply to help with Hydrolic lifter "Float"
Thanks again For the help..
....W...
.Found a Bent #1 cyl Intake valve stuck a new one in
#1 cyl it had low compression...
.. FELPRO head gasket
Old 23 Jan 2018, 09:54 am
I've never seen someone use a valve spring compressor that way. The adjustable "fork" end is what I always used on the spring. I put the solid piece in the center of the valve. But, hey, whatever works, right?
Old 23 Jan 2018, 07:54 pm
The spring compressor is just parked there and is in the correct orientation.
