Need help with a part #
Like Tree5Likes
Closed Thread
Old 21 Jan 2018, 04:55 pm
Default Need help with a part #
I have a 07 sedan, and on the inside, underneath the A pillar on both sides, there is this sponge like, gasket like, glued on piece that has disintegrated on both sides. I would like to replace them but can't seem to find any info. If you can help, Thank you.
Old 21 Jan 2018, 05:35 pm
Default Re: Need help with a part #
Can you post a picture of what you need?
Old 21 Jan 2018, 05:53 pm
rckstein's Avatar
I believe that would be item #10 in this diagram:
MOPAR 05152093AA SEAL Left A-Pillar Foam Blocker
MOPAR 05152092AA SEAL Right A-Pillar Foam Blocker
I have to go by local dealership tomorrow for something else, I'll find out if they are still available.
Old 21 Jan 2018, 06:02 pm
Have a look here also https://www.moparpartsgiant.com
Old 21 Jan 2018, 06:22 pm
rckstein's Avatar
I've used that website several times, but just because they list it, doesn't mean that the part is still available. It may even let you place an order and process your payment, but then you may get an email that the item has been discontinued.
My local dealership will tell me with no problems if the part is still available to order.
Old 22 Jan 2018, 10:08 am
Thank you very much 'rckstein'. I'll check with every web site I can find. Thanks again!
rckstein likes this.
Old 22 Jan 2018, 10:23 am
Both of those part numbers are discontinued on tascaparts.com. I always use this website and it always seems to be very up to date on what is or is not available. Their prices are good too.
https://www.tascaparts.com/oem-parts...llar-5152093aa
https://www.tascaparts.com/oem-parts...llar-5152092aa
Old 22 Jan 2018, 11:01 am
https://www.moparpartsgiant.com/part...5152092aa.html
Something I found when googling.
2016 Kia Soul Plus Black
Old 22 Jan 2018, 11:20 am
rckstein's Avatar
This is the part in question, you can how they split at the top, then will eventually break off.
Both parts are still available to order through your local dealership.
This is the prices I was given:
MOPAR 5152093AA $15.45
MOPAR 5152092AA $14.50
Old 22 Jan 2018, 11:37 am
If a part is Auto manufacturer discontinued and you still want the part you should ask one of the Dealerships that will work with you to do a part number search. There are many discontinued parts that are still floating around some parts departments at other dealerships. You might get lucky?
Closed Thread
Part Help alanrw Tech & Performance Forum 3 28 Apr 2011 09:44 am
ALL IN ONE Part....Help??! ucantcme General PT Cruiser Discussions 8 22 Aug 2008 04:03 pm
Do you need this part? KingKole02 General PT Cruiser Discussions 3 09 Jul 2004 04:06 pm
Name this part coolvirus General Turbo Discussions 18 26 Apr 2004 11:25 pm
pt part # tom Tech & Performance Forum 0 02 Oct 2002 09:07 pm
