Car exhaust coming in through AC vents
Like Tree2Likes
  • 2 Post By Renegade
Old 21 Jan 2018, 11:33 pm
brian2002utd's Avatar
Default Car exhaust coming in through AC vents
Just bough a used 2005 PT Turbo Convertible and have been working through some issues with it. Just when I thought I had exerything squared away I took it on the long haul to work (50mi each way.) Made it there with no problems but halfway back i started getting a strong smell of exhaust coming in from the AC vents. The problem would subside a bit if I turned on recirculate and opened the windows but not completely even with the top down things were fumey especially when idling in traffic. I bought a carbon monoxide detector today to see if it read anything in the cabin. It was not able to pick up any measurable levels but on doing some research I found that modern cars do not put out much CO anymore. The situation sucks, I dont like breathing in all that nasty stuff, gives me a headache! I am also adamant about doing my own work and hate taking my car to a shop. Could use some advice on where to start with this one. I am including a picture of soumething I notices when checking out an oil leak. It looks like a broken bolt on an exhaust connection. Perhaps thats where I should start?
Old 25 Jan 2018, 06:18 pm
Default Re: Car exhaust coming in through AC vents
Are you sure it's exhaust and not coolant fumes you're smelling?
Old 25 Jan 2018, 11:35 pm
044400's Avatar
I sometimes smell coolant when I'm coming to a stop. Not sure of the source. I dread the heater core.
2004 Turbo Lite Purchased 4 $400
Old 07 Feb 2018, 11:29 pm
It's not coolant fumes, my other PT has that problem!! I had it smoke tested by my mechanic and they found several leaks so I took it to a very reputable muffler shop and they supposedly repaired the leaks and the broken bolt but the car is still fumey both inside and out. I had an oil leak that was recently repaired, I wonder if the engine is just burning off the oil from the leak. I also put seafoam in the tank before the problem started so maybe thats it? The exhaust has some smoke or water vapor that I can see coming out of the tail pipe but that could just be the cold weather. I am stumped on this one!
Old 07 Feb 2018, 11:30 pm
Also after leaving the carbon monoxide detector in the cabin for a few days it did pick up some small levels.
Old 08 Feb 2018, 02:50 am
I started smelling that in mid-October. I tried some Bars Stop Leak in early January, but at the end of the month the core blew open even bigger. What I'm saying is don't let it go on too long or you risk overheating sometime when you are nowhere near home.
Since you are in SoCal like me, you can probably just do a heater bypass until you are ready to tackle the core replacement. That's the route I took for now.
Old 08 Feb 2018, 10:27 am
rob302's Avatar
if it were me, i would stick a shop-vac on the tailpipe and play around with a cigar, or you may opt to bring it back to be "smoke machined" again. it's also possible you have a crack in the exhaust manifold which could grow and shrink as it heats/cools. it's fairly common.
Smoke coming thru ac vents SaraT General PT Cruiser Discussions 16 05 Jun 2018 08:14 am
Steam coming out of vents in car ceil99 General PT Cruiser Discussions 14 02 Feb 2016 08:52 am
Gasoline Smell coming in Heater Vents 2002 PT Limited MarcusO Tech & Performance Forum 13 18 Jan 2016 01:05 pm
Always warm air coming out of the vents! ProDigit General PT Cruiser Discussions 9 27 Jan 2011 08:22 pm
Fluid coming out of exhaust... crazie.eddie General PT Cruiser Discussions 10 11 Nov 2004 04:21 pm
