oil pan leak
Old 23 Jan 2018, 02:54 pm
edscrz's Avatar
Default oil pan leak
I noticed a little oil on the garage floor and took car to a mechanic. He said oil pan gasket needs to be replaced, and charge is $335. As it is over 2 hours labor. Does this sound correct?
edscrz
Old 23 Jan 2018, 04:07 pm
Default Re: oil pan leak
Yes about right for the time. Closer to 2 hours unless it is a real mess under their. What some that are not in the business forget and don't know to account for is the X factor. That is how dirty vehicles is that needs to have things cleaned just to first get to the part needing attention. The flat rate guides only considers the perfect R&R situation. Keep in mind he will need either sealer or gasket and oil perhaps a couple misalinus parts?
Possible Leak? Jrosa Tech & Performance Forum 11 24 Feb 2015 05:52 pm
Oil Leak keebler95 General PT Cruiser Discussions 5 21 Jun 2013 04:03 pm
Oil Leak, Vacuum leak Ikster Tech & Performance Forum 1 02 Jan 2013 09:53 pm
oil leak Nickatnite Tech & Performance Forum 10 11 Oct 2011 08:45 pm
Leak. TallahasseeGT General Turbo Discussions 1 04 Oct 2011 09:40 am
