PRNDL switch not working
Like Tree6Likes
Old 23 Jan 2018, 05:29 pm
Default PRNDL switch not working
So I've got keys to start my newly acquired 09 NA automatic that had been repo'd.
NO Start.
PRNDL shows the car in 1st gear, Shift lever is in park.
The key interlock seems to be working. I have to have the key on to move the shift lever.
Somewhere I have a disconnect.
Ideas?
j
Handy_Cruiser likes this.
Old 23 Jan 2018, 06:05 pm
Handy_Cruiser's Avatar
Default Re: PRNDL switch not working
Here's what I posted in your other thread:
Chances are that the shift cable is messed up or out of adjustment. The repo company may have done this trying to get the car out of park without a key.
If me, I'd remove the center console and the air filter housing. Then I'd observe what's going on when I shift. It may be a simple fix.
Old 23 Jan 2018, 06:15 pm
Thanks Handy. Daylight is in short supply, I'll check tomorrow. j
Old 23 Jan 2018, 08:08 pm
Don't take the console apart. Does the trans hold the car in park and are you able to roll car when not in park? If so, the cable is fine.
On the front of the trans there are two plugs down low or one vertical, check these. ( see pics )
Old 23 Jan 2018, 09:23 pm
Thanks 06, on my list to check. Be nice if its that simple. j
Old 24 Jan 2018, 05:39 pm
It's ALIVE . The cable from the shift lever to the trans is not doing its job. Shifted the trans manually (at the transmission) to park and it started right up.
Now to figure out how to get the console off.
Car seems to run well, we shall see.
j
Old 24 Jan 2018, 06:05 pm
LionPT's Avatar
j
You will have to bend the console a little where the emergency brake handle goes to get it off & back on...unless you can pull your handle way up straight.
Old 24 Jan 2018, 10:40 pm
Thanks LionPT
Old 25 Jan 2018, 01:04 am
LionPT's Avatar
Also, if you have rear power windows the removal is the same except after you unplug the center power supply...lift the rear of the console a few inches to get your hands underneath to unplug the power window switch.
Old 25 Jan 2018, 08:10 am
ajhockey3's Avatar
Out of curiosity, where and how much did buy a repo'ed pt for?
2006 PT Cruiser Base 2.4L NA $250
Multifunction Switch - Headlights not working - can I use switch with Fogs? bwiencek General PT Cruiser Discussions 1 13 Oct 2014 01:51 pm
Flashers/Blinkers not working from switch. ChazBOT Tech & Performance Forum 6 29 Jun 2014 11:41 pm
replace PRNDL light bulb PTCharlie General PT Cruiser Discussions 7 16 Nov 2013 10:15 pm
dome light switch on S/W not working outfit Interior Accessories Forum 0 13 Dec 2010 04:17 am
door lock switch not working ptbooga General PT Cruiser Discussions 2 08 Oct 2005 06:00 pm
