Trouble Code P0700
Old 02 Feb 2018, 03:45 pm
Red face Trouble Code P0700
I have been struggling with this one for awhile. I have replaced both input and output Transmission Sensors and I still get the trouble code. What I found out today is that when you change the Sensors, you have to replace the wiring that goes to them. When you buy the sensors at Advance Auto or other, they don't tell you that. I found out the hard way. It is a Dealer Item and they are sold separate and not as a pair. They run $47.00 - $52.00 for each. This was the cause for the car not to shift into gear.
I hope this helps others about the Code P0700.
Old 02 Feb 2018, 07:53 pm
Default Re: Trouble Code P0700
P0700 is a generic code for the transmission. In order to get the specific codes that the transmission has triggered you would need an expensive OBD scan tool that will read transmission codes.
P0700 code that lies gmhiggins Tech & Performance Forum 7 04 Apr 2014 02:01 am
help I'm in mexico with code P0700 cintra07 General PT Cruiser Discussions 9 30 Jun 2012 07:48 pm
P0700 code & car won't start HELP! hectormc29 Tech & Performance Forum 2 05 Feb 2011 07:03 pm
P0700 code mash35231 Tech & Performance Forum 8 18 Oct 2010 06:01 pm
Beyond the P0700 code Vigilant32 Tech & Performance Forum 3 06 May 2009 04:47 pm
