Clutch Replacement Advise Needed
Old 08 Feb 2018, 09:11 pm
Default Clutch Replacement Advise Needed
Changed the master and slave and now the clutch on my 2003 base model is slipping, nearly gone! I am planning to R&R the clutch myself and need help with regards to any advise or tricks I need to know before I start the project. I just don't want to part with the car.... been with me since July of 2003. It's a part of the family now
I did get a copy of the shop manual and have watched the couple of videos out there on YouTube, but I'm sure there are some suggestions that you might have that will make the job go smoother.
It's not that I don't want to pay to get it done, there just aren't any shops out there that are willing to take on the job here in Hawaii. Or at least not for a somewhat reasonable price.
I don't have a lift but have 2 floor jacks and jack-stands and have taken on difficult projects like this before. Please let me know if you have any help or advise.
Thanks in advance!!
Old 08 Feb 2018, 09:23 pm
rob302's Avatar
Default Re: Clutch Replacement Advise Needed
here is a link to my simplified instructions i wrote, soon after i did it at home in my gravel driveway. 5 Speed trans removal,, clutch replace info?
it really isn't a bad job at all.
by cutting this socket down, i could loosen the flywheel bolts and the head of the wrench would prevent the flywheel from spinning. i cut the socket with my angle grinder. if you have an 18mm socket to sacrifice, keep this in mind. (or loosen the 4 flex plate bolts ahead of time by having someone step on the brake before you remove the axles 'n all that)
also highly recommend if your jackstands are the normal DIY shorties, you consider buying/borrowing tall/sturdy ones
Old 08 Feb 2018, 10:59 pm
_PTGT03's Avatar
get the valeo single piece flywheel+clutch conversion kit
and, a machined clutch to slave pivot arm . made by rage-tek
Old 09 Feb 2018, 07:39 am
rob302's Avatar
i beat a $145 stock modular self adjusting replacement pretty mercilessly with good result. was cheap, chirped third, self adjusting
Tags
clutch, home job, transmission pt cruiser
Advise on replacement seat upholstery sources ptprice General PT Cruiser Discussions 7 26 Apr 2017 10:31 pm
2001 PT - Engine mount replacement needed with Oil pan replacement? SanPT Tech & Performance Forum 14 23 Sep 2012 08:49 pm
urgent advise needed please oppsydaisy Tech & Performance Forum 2 22 Jun 2011 08:56 am
help and advise needed please with my pt cruiser oppsydaisy General PT Cruiser Discussions 3 21 Jun 2011 02:31 pm
