Trans "bump" when downshifting
Like Tree4Likes
  • 1 Post By rsrocket1
  • 1 Post By wingman55
  • 1 Post By Handy_Cruiser
  • 1 Post By 06_PB6_TOURING
Old 14 Feb 2018, 11:00 am
RVC RVC is offline
Default Trans "bump" when downshifting
I've read this can indicate a problem with the transmission but wanted to check in. It's an NA '02 with about 112K. Is this an issue that can be remedied without a specialist (i.e. - work on it myself?) or will I need a pro? It happens occasionally when I get down to around 15 mph +-. Thanks.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 14 Feb 2018, 11:26 am
rsrocket1's Avatar
Default Re: Trans "bump" when downshifting
Have you checked your upper and especially lower torque struts (engine mounts)? Torn bushings can make it feel like a transmission problem.
Coast to about 5 MPH, then push the accelerator (you don't have to floor it). If you feel a big clunk, that may be the engine twisting forward without a torque strut holding it. You can probably notice it by also pushing the top of the engine forward and back. If you feel little or no resistance, the torque strut bushings are worn out and torn.
If that is the case, the good news is the upper and lower torque struts are about $10 each and take about 1/2 hour to replace and adjust (important to adjust them).
Handy_Cruiser likes this.
Old 14 Feb 2018, 11:54 am
RVC RVC is offline
Thanks. Wish it was that simple but I replaced both those struts about 2k ago.
Old 14 Feb 2018, 12:19 pm
wingman55's Avatar
Have you checked the Transmission fluid level? Or maybe it's time for a flush and fill with a new filter.
Just some quick ideas.
rsrocket1 likes this.
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
Old 14 Feb 2018, 01:22 pm
Handy_Cruiser's Avatar
First, listen to rsrocket1. It may well be a torque strut or the passenger side center mount.
If no joy, another thing that can cause a bump on a downshift is a bad CV joint. This is because the direction of force reverses on a downshift so if the joint has slack in it, it will bump when the force is reversed. The inner joint will be more likely because the outer one will often click and bump when turning. And if it's a turbo PT, check the intermediate CV shaft carrier bearing as well.
podo2000 likes this.
Old 14 Feb 2018, 06:53 pm
Does this bump occur while coasting to a stop or when you get back into the throttle while rolling?
My 06 with 162 K has the occasional 2 - 1 bump when getting back into the throttle. In my case the trans down shifts at slightly too high a road speed and the motor does not have a chance to get up to speed. ( The down shift occurs at throttle tip in )
https://www.sonnax.com/units/21-40te...52D1%2520Harsh
wingman55 likes this.
Old 14 Feb 2018, 08:24 pm
Is your enginee light on? If so what codes are you getting?
2003 pt gruiser gt "clunk/crunch" sound from trans when clutch in Bmxer300zx Tech & Performance Forum 1 15 Mar 2016 10:41 am
The "Handy" NOPI Strut Bar Install: Part "Deux" (2) Handy_Cruiser Tech & Performance Forum 2 01 Aug 2015 10:37 pm
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
"Seafoam TRANS TUNE" on a automatic Transmission? RedPT07 Tech & Performance Forum 12 21 Sep 2010 11:55 am
