Engine running super fumey (smelling unburnt gas)
Like Tree3Likes
  • 1 Post By brian2002utd
  • 2 Post By brian2002utd
Old 15 Feb 2018, 01:02 am
brian2002utd's Avatar
Default Engine running super fumey (smelling unburnt gas)
Ok I've got a mystery here. I bought a 2005 PT Turbo Conv a few months ago. All was good for awhile untill I started getting fumes in the cabin. Had it smoke tested and took it to a muffler shop to fix the leaks. The fumes smell like unburnt gasoline and come from all around the car while running and if I turn on the vents w/o recirculation its an intense smell of what smells like gas fumes to me. Sometimes also I can smell gas in the garage when it hasnt been driven for awhile. Any ideas?
Old 15 Feb 2018, 08:21 am
Default Re: Engine running super fumey (smelling unburnt gas)
A fuel line that's cracked and only leaks under pressure? Have you checked the fuel pump pressure to see if it holds? 58 is the recommended, I THINK.
Old 15 Feb 2018, 09:49 am
rob302's Avatar
If you follow the fuel line back from where it meets the fuel rail, there is a small metal canister the size of an acorn on the firewall that is prone to leaking. I would check that first.
Cycle the key from off to run a few times, then have a look.
Old 15 Feb 2018, 11:26 am
Your Pt Cruiser might have a short plastic fuel line coming from main gas line connecting to the fuel rail at the fire wall that is leaking. This gas leak will let gas fumes enter the cabin when you turn on the A/C or heater.
Old 15 Feb 2018, 01:14 pm
Handy_Cruiser's Avatar
The fuel line that goes from the firewall the injector rail can get really crispy on a turbo PT. If this is you issue, here's a link to a way to make something more beefy. It doesn't meet racing specs. But if you plan to go race, get something else besides a PT Cruiser.
Handy's New Turbo Convertible PT Project!
My problem was similar to yours but less severe. It actually turned out to be a crack in the weld on the injector rail. Here's link to how I fixed it:
Old 18 Feb 2018, 12:13 am
Wow thanks for the detailed info everyone! I will check it out as soon as work lets me have a day off! Hopefully it will be a simple repair. Love the expertise in this forum!
Handy_Cruiser likes this.
Old 18 Feb 2018, 09:27 am
I changed the line in question immediately after buying my 06 NA with 162 K. There is a non turbo car in the self serve scrap yard that had a fire on the passenger firewall area that sure looks like it started at that line.
There was also a non turbo car with 30 k ish miles at a salvage auction that had a passenger side fire as well. ( didn't get a close look at that one )
The factory line is about $ 50 and includes the pulsation damper. Or it might be a low cracking pressure check valve, I haven't tested yet. This check valve would stop fuel flow in the event of a crash that broke the fuel rail and tank was under pressure / elevated above the failed line.
Old 19 Feb 2018, 12:46 am
Mystery solved! After cycling the fuel pump several times and not smelling anything in the engine compartment and scratching my head I noticed that the air box lid wasnt latched. After latching it the smell went away, after scratching my head some more I realized that the PCV hose on the turbo vents to the airbox and not to the intake like the N.A. PT. I need to replace that hose also because it is cut too short to make a solid connection at both ends so off to Pep Boys tomorrow for some 3/8" fuel line to cut to the correct length. Its funny I have been all over this car trying to identify the issue and doing so much reseach online and it was all because I didnt secure the guides before I latched the air box after changing the filter!! We all have our learning moments!!
chuzz and Azrak like this.
How to SUPER CLEAN your Engine Bay 044400 The Detail Shop 5 06 Dec 2017 12:57 am
smelling oil....... kpl1228 Tech & Performance Forum 3 26 Apr 2015 08:24 pm
Engine fan running whitec1001 Tech & Performance Forum 4 12 Mar 2013 03:10 pm
engine running hot? myPTandME Tech & Performance Forum 2 06 Mar 2011 08:32 pm
HELP! Key's Are Out, Engine Still Running! mentrc Tech & Performance Forum 0 04 Oct 2002 02:53 pm
