B1B70 and U0170, Srs light on
Old 28 Feb 2018, 11:11 pm
Default B1B70 and U0170, Srs light on
I understand its something to do with a sensor in the dash. How would i test this or should it go to a mechanic? Also how much would it roughly be for a mechanic to diagnose/fix
Old 28 Feb 2018, 11:39 pm
Default Re: B1B70 and U0170, Srs light on
I would suggest checking the wiring and wire connectors going to the front impact sensor. Make sure you know what you are doing so you don't trigger the airbag.
B1B70 Front impact sensor internal failure
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
Left Side Break Light / Blinker / Reverse Light MaxJoseph Tech & Performance Forum 6 07 Nov 2015 05:18 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
