can't put gas in tank
Old 01 Mar 2018, 01:22 pm
Default can't put gas in tank
I Can't put gas in tank without it spitting back and kicking the pump off. Any ideas? Thanks
Old 01 Mar 2018, 01:57 pm
Default Re: can't put gas in tank
How did you fix it the last time you had this problem or is this a different Pt Cruiser?
pt won't accept gas
Old 01 Mar 2018, 02:51 pm
Same car. I took it off the road and have been driving my other one. I'm thinking I'd like to put it back on the road this spring. I haven't played with this one in a year now. My buddy had the same problem with a chev Blazer said it was a canister under the hood. Is this possible?
Old 01 Mar 2018, 05:56 pm
What year? This is from the 06 manual.
I don't have a clear description on flows, but I'd say:
When filling, air exits through 5 / 7 , some goes back up the vent tube 6 but most goes through 12 on it's way to canister 14. The flow might also be through 10 then to 12 / 14.
Item 5 is a check valve, if this is stuck air can't escape during filling. Item might contain a check valve as well but I tend to think this is for vapor recovery post filling.
Modern cars have vapor recovery during the filling process in addition to vapor recovery when the car is sitting. If the vapors ( air ) can escape then filling, the tank acts as it is full.
Old 01 Mar 2018, 11:41 pm
_PTGT03's Avatar
the evap system is completely clogged. the gas vapors are building up causing a back pressure to push the release diaphragm on the filler handle.
you would have to learn how all the breathing systems work first and then you potentially have to take out the tank and test all the components. i suggest to get the alldata and read the description and operation for the fuel tank and evap system.
Old 03 Mar 2018, 08:10 am
Thanks for the input. It's a 2001. I guess some things are allowed to clog up it has 211K on it. Sounds like a summer project . We just got 20" of the wettest heaviest snow I have ever seen. But we're another day closer to spring.
Old 06 Mar 2018, 04:52 pm
Vengence's Avatar
Couple things to check on that. I just had this issue myself and got it fixed last week along with the other issues i was having.
For me, the issue was a Check Valve in the Gas Tank. Which can not be changed separately. So the solution was to buy a new gas tank. $700 for a new tank but I opted to buy a certified used tank. Worked out well so far. However, this may not be the case for your PT. It may or may not. However other things to look at is a ball or something in the fuel/evap system ( which i was told that ball only prevents people from from syphoning gas from the tank) and a possibly clogged charcoal canister. But, i would have to say that your issue is the Check Valve in the gas tank. My guess as it was my issue. Total cost to me for the used tank and labor was $500.
My PT's-
2008 PT Cruiser LX Inferno Red
2003 PT Cruiser Base Woody Edition
Old 06 Mar 2018, 05:21 pm
This check valve / ball in the inlet of tank is to prevent fuel loss during a roll over / fuel filler being damaged / cap left off.
There is also a check valve in the evap vent to prevent liquid fuel from entering the evap system either by overfilling or roll over.
Old 07 Mar 2018, 09:00 pm
Vengeance, I'm only about 20 mi from you in Colden 10 mi due south of E. Aurora. Small world,
The gas tank.. ucantcme General PT Cruiser Discussions 47 22 Aug 2016 11:01 pm
GAS TANK DOOR intrepid1994 Classifieds: For Sale/Trade 3 07 Aug 2014 07:15 pm
Water in gas tank? scrubz23 General PT Cruiser Discussions 12 07 Jan 2014 05:45 pm
I'm only getting 120Miles to a tank.... rubsnick General PT Cruiser Discussions 20 03 Oct 2009 09:02 pm
Gas Tank BruisersCruiser General PT Cruiser Discussions 5 14 May 2004 04:42 pm
